Question about Sony Bravia KDL-46HX729 LED Internet TV Compatible Full Motion Articulating TV Wall Mount Bracket Living Room/ Fireplace/ Game Room Extends 32 Inches
When turning on my bravia 32 is all black and then lines in color appear and then black again
Only turning on and nothing shows
    Top Expert:
  • Sony Master
  • 75,304 Answers
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 23, 2014
ahughs
  • 13 Answers
SOURCE: Bravia Color
why can't you adjust the color? What do you mean
Posted on Mar 27, 2008
welcomejee
  • 10594 Answers
SOURCE: Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Posted on Dec 13, 2009
  • 49 Answers
SOURCE: verticle lines for picture
You need to describe these lines better. Are they moving or stationary? Are they very fine lines with sharp edges or are they more like bands with soft edges? How many lines do you see, and how wide are they (compared to the screen width)?
Fine lines that are stationary: defect in the electronics causing a vertical row of pixels to be dead or stuck. Can only be fixed by replacing major parts.
Broad lines with soft edges that move: could be electrical "hum" interference. Make sure you are using a grounded (3-pin) power plug, and that the outlet is properly wired. (Take the TV to a another location and see if the problem goes away).
Make sure you don't have fluorescent light fixtures nearby--they can interfere with the picture if the bulbs or ballast is defective. Could mean tecon board or display is bad which means replacing both in a sony if they are bad i recomend buying a new tv because it is not cost effective to replace these.
Posted on Dec 14, 2010
SD Tech
  • 14553 Answers
SOURCE: Sony Bravia LCD TV. There's a horizontal black line appearing just below the center of the screen. Have observed it's getting longer.
it may be the display panel especially if the line is black.
Some tests are needed and maybe a board swapped etc but if it turns out to be the Panel the part costs more than the set did when new===fatal.
Posted on May 26, 2012
SD Tech
  • 14553 Answers
SOURCE: my sony Bravia kdl-46v5500 screen has colored lines on the left side then half the screen flicks black then the same left half side of the screen stays black then will go back to normal and then go
These sets use for the most part two boards--each drives the screen on one side---also possible as suggested here the problem is inside the panel or where it connects to these boards--if inside the panel (the entire front screen unit) it is fatal as it cannot be got at and the display costs more than the set did new.
Posted on Oct 30, 2012
No picture, vertical colored lines
I have never heard of a warm-up problem on a digital television. Unlike the old CRT TVs and monitors, digital panels don't have to warm up. I would go with the TV repair persons assessment that you've got a bad panel.
Jan 04, 2018 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
How to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
how to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
Jan 22, 2011 | Sony BRAVIA KDL-V40XBR1 Television
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
Vertical Line
could be the logic board, but , unfortunately, more likely the lcd panel itself. very unlikely to be economically repaired. new panel and labor a few hundred $'s less than new tv
May 24, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL-46HX729 LED Internet TV Compatible Full Motion Articulating TV Wall Mount Bracket Living Room/ Fireplace/ Game Room Extends 32 Inches Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
