Vizio VM60P lost picture. No menu either. Caps look good with no bulging or leaking. Fuses look good. There was sound, but now there isn't. Not sure what current settings are because I can't see the menu. Took the middle panel off the back and don't see anything that jumps out at me as wrong. Vizio tech says buy another. Lol. They can't even tell me what the light source is. Tried telling me it was LED.
    Problem Solver:
  • 11 Answers
Could be the power board, even though the caps look good.
Posted on Nov 23, 2014
javswr
  • 44 Answers
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Posted on Feb 28, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: vizio gv47lfhdtv10a no picture no sound
Well guru way to help him out with his problem maybe he doesnt have the money to just run out and buy a new one...
Posted on Mar 21, 2010
info33
  • 72 Answers
SOURCE: Vizio VO37L LCD will not display picture. Screen
Here is teh quick start guide from Vizio - make sure your set up is correct and the inputs are in the right place. Follow this -
http://www.wigix.com/index.php/skuaccessories/downloadManual/2166516/10708/0/Vizio-LCD-Flat-Panel-TV---37-VO37LFHDTV10A-Quick-Start-Guide.pdf
Posted on Jul 03, 2010
My flat panel tv has sound but no picture, its a Akai model pdp42z5ta. I replace the invertor board but its still the same, all 5 fuses and are good, at 1.0 ohms. What should I do now.
Hi, Check main power board for bad Caps. Replace caps with same rated or better caps.(Capacitors). Look for bulged or leaking caps. Good luck
Nov 21, 2016 | Akai Televison & Video
VIZIO DTV WONT PICK UP CHANNELS
the freeview board has failed easy to change it is just clipped in on to the board. that also could be the fault it may have come out of its conector.
Oct 02, 2013 | Vizio VM60P 60 in. Plasma TV
Vizo VM60P HDTV10A will not power up. Logo Dark
the unit needs to be examined by someone able to do so---first place is to look at the power supply for the set......
Aug 26, 2012 | Vizio VM60P 60 in. Plasma TV
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
My vizio 37 inches hdtv went black with no sound. can this be fixed?
Yes,power of the tv just have a tv LED power light indication flashing or blinking only?Yes.Tries tv unplug,replug it back like about an hour later for the tv to do a whole resetting itself back to factory setting.Tv should be working again.If not than the tv power supply board have a problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish a tv power supply board for the replacement.
Sep 03, 2011 | Vizio L37 Television
Have a vizio 47" vo47lfhdtv10a,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this helpout in solving the problem...
Jun 09, 2011 | Vizio SV470XVT 47 in. LCD TV
42" magnavox lost picture but
Power supply problem. If you have electronic experience pull the rear of the panel and look at the power supply and check for bulged or leaking or busted caps replace them and i will probably be good to go. if you cant do component level repair order the whole board and also dont kill yourself - tv voltages and amperages are strong enough to kill a human.
thanks,
Michael
Feb 07, 2011 | Televison & Video
BLACK SCREEN
There two possibilities:
1) there is no 24vdc output feeding the backlightinverter board due to blown parts, bad caps with leaking/bulging tops.
2) Backlight inverter board is bad, blown fuses, transistors, IC.
So, look for 24vdc first.
Parts/;
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VO47L+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Vizio VO47L 47 in. LCD TV
Sound is good, but no picture; the ruby vizio does not light up
Ur LCD inverter board it dead,replaed that u get picture back.
Nov 23, 2009 | Vizio VM60P 60 in. Plasma TV
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
Electro Med Services...
