Question about Dometic RM2620R Classic Fridge Refrigerator Refer 2-Way Small Double D
My RM 2620 wont stay on when swithcing over to gas or AC. When I turn the unit off and shortly after back to On, it will then after 45 sec show up Check.
Corrosion removal on connectors.
  • Official Brand Answer
  • 73 Answers
It is more then likely a ground wire conection problem.
Posted on Dec 05, 2014
3 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: My domestic rm 2620 shuts
If your unit keeps on going off immediately after putting it on this problem is as a result of a couple of things. Firstly this unit is made to support voltages of 120 - 110 if your location supports 220volts then the unit might have been damaged and would need a lot of work and an expert to handle it.
But if not then the power module or the PCB conductor or thermistor conductor is responsible for the problem and might need changing. Usually it is advicable to get an expert to check the unit and determine exactly which of them or if both of they all have to be replaced.
Hope this support has been helpful?
Posted on Jul 11, 2011
  • 147 Answers
SOURCE: rm 2652 checklight comes on after turning unit on. while plugged into 120v
What is your location?
Posted on Aug 28, 2012
I have a Dometic RM 2620 fridge, that won't cool. A squirrel got into wiring, I have taken care of wiring but will not work on gas or AC. Spark igniter will no spark either. Any ideas?
Since I don't know what does work I am kind of shooting in the dark.
Does the ac heater get hot ?
The spark ignitor is part of the control board. But won't work?
I assume that you have a user manual but I am including a link to download one.
https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc
Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack.
If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
Sep 19, 2014 | Dometic RM2620 Refrigerator
When I plug the monitor it won't stay on. Why?
1. CRT or LCD?
2. Do you have an image of any kind for that 45 sec.?
When it drops out after 45 sec, do you have any strange behavior as you look at the screen (colors, blinking, lines, squiggles, noises, smells)?
3. When failing, does the power drop out (ON light goes OFF)?
How long do you need to wait until you can turn it ON again?
4. What is the status of your screen saver/power saver? 45 sec seems pretty short but it's still possible.
5. What does the manufacturer's website have to say about this problem? What do other users have to say when you search for your model?
I know these are just more questions but your question is too generic to offer specific comments that might be more useful.
Apr 12, 2013 | Computers & Internet
It wont stay power up;and screen stays black; and shuts down after a second' please help'''''
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron 1501 Notebook
When go to turn on laptop wont stay on lights up like it is going to stay on but shuts down as soon as you lift off your finger
remove the battery and ac adapter and hold the power button for 10 sec and remove all the external devices and connect the battery and ac adapter and try if no try diffrent diffrent ac adapter or wall unit
Aug 17, 2009 | HP Computers & Internet
Dometic rm 2620 fridge problem
The flame is not hot enough check gas pressure
Jun 22, 2009 | Dometic RM2620 Refrigerator
Air wont get cold
yes just get the info on the unit for the type of gas in the system and the may sell the gas at an auto store near you
Apr 27, 2009 | Dometic Rooftop RV Air Conditioner
My RM 2652 when dry camping it uses the 2 batteries overnight ?
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp
(A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system
will automatically select between AC and GAS operation with AC having priority over GAS. If the control
system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45
seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B)
will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press
the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a
new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds
to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks
have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require
resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas
operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in
the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated
after 3 or 4 tries.
Nov 18, 2008 | Dometic RM2652 Refrigerator
Garmin Streetpilot 2620
Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"4f3efc6.jpg
Sep 23, 2007 | Garmin StreetPilot 2620 GPS Receiver
Dometic RM2620R Classic Fridge Refrigerator Refer 2-Way Small Double D Logo
75 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
