Question about Mitsubishi Mistubishi Lvp-x80u Lcd Projector
My batter y keeps dieying
My battery keeps dieying
  • Mitsubishi Master
  • 3,368 Answers
Get a new one or charge it more often.
Posted on Nov 27, 2014
Why doesn't it charge?
The battery may have to be replaced.
Feb 13, 2016 | LG Radio Communications
What would cause the vehicle to keep depleting batteries?
Sounds like you alternator might not be charging. If you can charge the battery and get the vehicle to a parts store, like an Oreilly's or Pep Boys, they will be able to test your charging system and determine your problem.
Nov 23, 2015 | 2001 Suzuki Grand Vitara
If battery terminals keep getting corroded w/battery acid will the battery end up bein bad and not working
if you take it to a place that sell batters they should be able to test the batter and charging steam for you if not you can buy a tester of your own. If battery and charging system is ok then many places will sale you a grease or pad that will help stop corrosion on terminals.
Apr 01, 2015 | Cars & Trucks
Why does my battery keeps dieying
You probably need a new battery if it doesn't hold a charge. Average lifetime of a battery is about 2 years. Look on the outside of your battery and there should be a label with a year and month punched out which will tell you when it was made. Look inside the battery to see if there is corrosion or low water. If the water is low put in distilled water, fill it not quite full but so the water is above the metal plates then charge again. If its corroded it won't charge well. If it takes a full charge then dumps it once its put back in the car you will need a new one.
Nov 22, 2014 | Mitsubishi Galant Cars & Trucks
Does 1999 dodge have a safe proof device to shut truck off when you remove batter cable
yes it does, how ever if you are removing batter longer than 24 hrs you will need to plug a 9volt batter threw the cigarette lighter to prevent the comp. from totally deprograming it self. some times it will but in30 % of the time the computer will need flashed after reinstall batter for it to work again. if you don't keep 9volt constantly running to the computer.
Aug 19, 2014 | 1999 Dodge Durango
How do I change a battery of a 2011 Cruze without affecting the radio and other electronic systems?
take the batter n a pair of jummper cabels n a tahas them to youer old batter .now keep in mind that at no time r u let the cabels come loaes of the batter .or u can put a 12 vote batter crager in the cig liter soxit n run it as the batter untill u put the new one bake in the batter old batter place i hope this holp u out
Aug 01, 2013 | 2011 Chevrolet Cruze
I have a 2010 Impala just back from the body shop batter cable and terminals replaced and now the batter saver keeps coming on the battery and alternator tested good
Is the cable used strong enough for the battery power going through ?
How is the earth wiring tight ? The place where the earth wire tightened on the contact place body or engine block is it clean not painted?
Aug 23, 2012 | 2010 Chevrolet Impala LT
My expedition keeps dying on me the battery dies once i get it started though it works fine its when i leave it parked over night there is a new alternator on it cause the old one went out and the battery...
I'd run it by Autozone if this was the batter that was in it when the alatnator went out it may have cause the batter to get a bad cell, they will check it for free, Most batters have a 3 to 5 yr. warrenty. DONT tell thim your alatnitor went out if the battery showes bad this will void the warrenty just simpley say my batter has a bad cell....of corse the place you bought the batter will test it as well befor they give you or pro-rate your old battery good luck
Dec 24, 2010 | Ford Expedition Cars & Trucks
2003 Nissan Altima battery problems.?
charge the battery with a charger. Next start car and hook volt meter accross battery terminals should have 14+ volts, if not alternator bad.
May 10, 2010 | 2003 Nissan Altima
Mitsubishi Mistubishi Lvp-x80u Lcd Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
