Question about Boston Harbor Dryers
BOSTON HARBOR CF-78042 CEILING FAN MAKES A CLICK SOUND AND THEN THE LIGHTS TURN OFF BUT THE FAN WILL STILL WORK. IF I TURN THE SWITCH OFF AND BACK ON THE LIGHTS WORK FOR A UNKNOWN AMOUNT OF TIME BEFOR
BOSTON HARBOR CF-78042 CEILING FAN MAKES A CLICK SOUND AND THEN THE LIGHTS TURN OFF BUT THE FAN WILL STILL WORK. IF I TURN THE SWITCH OFF AND BACK ON THE LIGHTS WORK FOR A UNKNOWN AMOUNT OF TIME BEFORE THE DREADED CLICK AND THEN ITS LIGHTS OUT AGAIN. ANY HELP WOULD BE APRICIATED
  • 37 Answers
Have the lamps been replaced with ones with more than 60 Watts? Make sure all lamps are 60 watts, or less. Try 40W bulbs. If that fixes it, you just had lamps that were too hot. If not, you will probably need to replace the lamp control module. Try Boston Harbor's web site or try your local hardware store.
Posted on Nov 22, 2014
Testimonial: "Thank You! I will check the watts, I know we had one go out before and my wife replaced while I was working so I will double check, thanks again!!!"
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
SOURCE: ceiling fan makes a clicking noise
just apply some lubrication and if necessary change the ball bearings. u r all set
Posted on Oct 07, 2008
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Posted on Nov 25, 2008
extreme7528
  • 108 Answers
SOURCE: ceiling fan and light with remote turns on and off by itself
Both the remote and reciever in the fan base have the ability to have the codes changed. What is happening is you are getting radio interference that is causing the problem. Change the codes by either switching the switches in different positions or adding more dip clips that came with the fan. In any case change the codes in both the reciever and remote to the same code and you should no longer have a problem. Usually the place to change the code in the remote is in the battery area and are small switches (usually 5 or 6 of them) and unfortunately you will have to take the fan down to do the one there.
Posted on Oct 12, 2009
maintenacemi
  • 95 Answers
SOURCE: My bathroom exhaust fan makes a clicking noise,
fan blades touching sides of housing,also runs caused by back draught
Posted on Nov 18, 2009
I broke a shade on my harbor breeze lighthouse II ceiling fan, will you find the model number so I can order one?
Wrong way round, YOU tell us the model number and type and we tell you where to get the shade. You can see the fan in your house, but we can't. That makes it really difficult for us. Some shades are plain, some are fluted, some have patterns.
All is not lost though. Go here and take your pick. They all sell them including Harbour Breeze themselves..
  1. The Home Depot® - homedepot.ca‎
    Adwww.homedepot.ca/fans This ad is based on your:
    • current search terms
    • recent searches on Google
    Visit Google's Why This Ad page to learn more or opt out.
    Discover Canada's Online Source for Ceiling Fans & Lights. Shop Today!
.spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
Search Results
    Shop Ceiling Fan Parts & Accessories at Lowes.com
    www.lowes.com/Lighting-Ceiling-Fans/Ceiling-Fan-Parts.../_/N.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass ... Missing: lighthouse
    Shop Ceiling Fan Light Kits at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Light.../pl Harbor Breeze 2-Light Bronze Ceiling Fan Light Kit with Frosted .... Harbor Breeze 4-Light Antique Brass Ceiling Fan Light Kit with Shade Not Included Glass or ... Missing: lighthouse
    Shop Ceiling Fan Globes & Shades at Lowes.com
    www.lowes.com/...Ceiling-Fans/Ceiling-Fan.../Ceiling-Fan-Globes-Shade... Shop a variety of quality Ceiling Fan Globes & Shades and Ceiling Fan Globes & Shades that are available for ... Sea Gull Lighting (2) ... Harbor Breeze Opal Round Frosted Glass ShadeHarbor Breeze Opal Round Frosted Glass Shade. Missing: lighthouse
    Amazon.com: Harbor Breeze - Ceiling Fan Light Kits ...
    www.amazon.com > ... > Ceiling Fan Light Kits Lighting & Ceiling Fans All Home Improvement Best Sellers Lamps & Shades Ceiling Lights ... Harbor Breeze Springfield II 52-in Antique Bronze Downrod or Flush Mount Ceiling ... Harbor Breeze 52-in Springfield Brushed Nickel Ceiling Fan with Light Kit ... Harbor Breeze Outdoor/indoor Lighthouse Kit Weathered Copper.
    harbor breeze light kit parts - Harbor Breeze Shop
    harborbreezeshop.com/tag/harbor-breeze-light-kit-parts/ Jul 25, 2012 - You can also have the option of choosing different lamp shades, or if in case ... The 52? Harbor Breeze Avian ceiling fan with a built-in light kit from .... has a style inspired by the clean, strong lines of a welcoming lighthouse.
Feb 01, 2016 | Dryers
Need a new remote..#UC7067RC
Never heard of Boston Harbor but if it has an add-on remote, the Lowes one should. Make sure it comes with new receiver.
Apr 14, 2015 | Boston Harbor Dryers
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
Light switch by westinghouse 77020
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 16, 2012 | Westinghouse Electric Ceiling Fan 3-way...
Installation of wall remote for harbor breeze ceiling fans
Nov 17, 2007 | Dryers
Dryers Logo
65 people viewed this question
Top Boston Harbor Dryers Experts
Are you a Boston Harbor Dryer Expert? Answer questions, earn points and help others
