Question about Toro Garden
How do I replace a fuel tank on a toro 38586 snowblower that is leaking?
Nothing
  • 755 Answers
You need to remove the body cover first. The fasteners are all around the edge of the cover. Once that is free you remove the gas cap and lift off the ocver. The tank is only held on with a couple screws. A new tank can be sourced online for about 30 bucks. At bit pricey I know but it is a discontinued unit. Be safe and good luck!
Posted on Dec 01, 2014
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
Toro s-620 fuel primer button broke
any primer bulb will work if you install it between gas tank and carb in the fuel line
Jan 06, 2015 | Toro Garden
How do I replace a toro 38586 fuel tank
It's a pain to get the covers off these Single Stage machines but after that. the tan should be easily accessible
Nov 22, 2014 | Toro Garden
How to fix a leaky Toro 20007 fuel tank
If the fuel tank is metal take it off and clean the seam with sandpaper and use JB weld to repair it- If plastic tank, use a glue gun.
Apr 18, 2014 | Toro Lawn Mower With Toro Power Tools
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Snowblower leaks gas on garage floor
Is it coming from the carb or tank? Either way replace the fuel lines, they crack an get pin holes in them an cause problems. If it comes from the carb get a rebuild kit an, very cheap, an replace the seals.
Feb 28, 2014 | Toro Powerclear 221qe Electric Start...
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
I have a toro snowblower. i cannot pull the pull cord. it feels like it is stuck.
Pull your spark plug out and see if the cord will pull out, if it does than that means your cylinder is full of gas which is a result of ethanol in the gas causing the needle valve to leak causing fuel to siphon from tank to cylinder, pull your carb off and put a carb kit in and you will be blowing snow in no time,if this isnt the problem then enjine may be seized up and its time to replace blower. Good Luck!
Oct 07, 2011 | Toro Lawn Mower With Toro Power Tools
Just cleaned out my father's garage and came up with a Toro 524 snowblower this unit has not been running for over 6 years what should i do to get it up and running? can't find an owner manual online...
You need to clean the carb, make sure fuel lines are not cracked and brittle (replace if necessary) , clean fuel tank thoroughly, especially if there was still fuel in tank. Check for spark, mix a new batch of fuel (if mix is required) and start that mother it will probably run as good as new. Good Luck...
Nov 07, 2010 | Toro Blowers Rake and Vac - Electric...
Toro 521 snowblower..nn replace gas line to carb, it runs inside the engine cover..removed all bolts but the back cover doesnt seem williing to be removed
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
Oct 29, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
