Question about Home
How do I set by clock back three hours?
WE PUT NEW BATTERIES IN AND IT IS 3 HOURS AHEAD OF TIME.
  • kakima Nov 22, 2014
    What make and model?
  • 30 Answers
Remove batteries, set time to 5:45, then replace the batteries. Now set the time to 6:00, and it should strike 6 times. Hope this helps.
Posted on Mar 04, 2015
SOURCE: atomic clock sky scan model 87801
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
Posted on Nov 20, 2008
SOURCE: A few days ago the
yes
the positon of minute hand not sync with chime strikes.
you fix the minute hand as 15.minute slower and adjust the current time using time adjuster switch not with minute hand ok.
try it and solve it
SOURCE: Skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone
and select your zone then press set button.
SOURCE: How do I adjust the time zone. I set the clock
Take out the batteries, let stand for about 30 sec replace batteries and reset clock, when ask if you want to auto set daylight time "yes", and continue.
Posted on Oct 16, 2009
Kewyn
  • 103 Answers
SOURCE: my solar clock needs setting. I set it back an
1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
5) Now press the "set" button again six times. The time zone characters will flash.
6) Press the "adjust" button untill your time zone appears.
7) Press the "mode" button to return the clock to normal operation.
8) Press the "adjust" button to display the day-of-week.
Posted on Nov 09, 2009
How do I set my clock back an hour? It is the wrong time. My daughter set it ahead not realizing that it would change itself for daylight saving time.
Most digital clocks do not have the ability to move backwards. It is simply a matter of moving the clock hours forward 23 hours and you will be right back where you want to be. I hope this helps.
Mar 11, 2015 | Audio Players & Recorders
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    Clock is 2 hours ahead of actual cst time
    If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
    Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
    I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
    May 06, 2011 | Watches
    Since DST started I cannot get my radio controlled clock to reset to the actual time. I replaced the battery and now the clock will set itself four hours from the time it stopped, then stop again. i have...
    take the batteries back out and leave them out for at least 2 minutes. next put the batteries back in and put the clock near a wall or window so that the back of the clock faces colorado (where the WMV transmitter is),. It will most likely take all night for it to set properly, just after you put in the battery make sure that you have set your time zone on the back of the clock and if there is DST button press that too. just be patient, it will set itself. worse comes to worse you can set it by hand, but kind of defeats the purpose of having an "atomic clock". by the way the reason they call it "atomic" is becausee WMV's clock is tracking the decay of the Seisum atom, or some such bs.
    Mar 17, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    THE CLOCK IS THREE HOURS OFF
    My clock had a button on the back of it for DST/Time Zones. If your clock has this, it needs to be set to the correct time zone for your area. That would account for it being off 3 hours. Hope this helps.
    Jan 31, 2010 | Acu-Rite Audio Players & Recorders
    My clock radio wont keep the time once I set it the clock advances 2 to 3 hours ahead
    I took the back up battery out and unplugged the unit for about 20 minutes before powering the clock back up. Once I powered the clock up I re-inserted the backup battery.
    Jan 17, 2010 | Emerson Smartset Clock Radio
    Clock jumping forward 3 hours
    Ouch, sounds like it's TIME for a new clock
    I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
    Mar 12, 2009 | Philips MCD708 System
    Time on Outlook Express is wrong
    I solved the time problem when I realized that the computer thought I was on Pacific coast time. I found the setting to move to east coast time. I then reset the clock to my correct EST, and everything is good now.
    Sep 28, 2008 | Microsoft Office Professional 2007 Full...
    Home Logo
    82 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
