Question about Toro Garden
<!-- from fixya rte -->How do I replace a toro 38586 fuel tank - Toro Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
It's a pain to get the covers off these Single Stage machines but after that. the tan should be easily accessible
Posted on Nov 25, 2014
Toro 621 r/e. with choke all the way in,engine keeps surging?
Start with cleaning or replacing the air filter and fuel filter, if this help, then you have been lucky.
If not, then you must clean out the carb, it could be clogged, blocking air and fuel intake and fuel jet.
Also, if this is first run for quite some time, remember to change any fuel lying in the tank. It can be good practice to empty tank after use if it is going to lay idle for any length of time.
Dec 23, 2017 | Toro Garden
Toro s-620 fuel primer button broke
any primer bulb will work if you install it between gas tank and carb in the fuel line
Jan 06, 2015 | Toro Garden
How do I replace a fuel tank on a toro 38586 snowblower that is leaking?
You need to remove the body cover first. The fasteners are all around the edge of the cover. Once that is free you remove the gas cap and lift off the ocver. The tank is only held on with a couple screws. A new tank can be sourced online for about 30 bucks. At bit pricey I know but it is a discontinued unit. Be safe and good luck!
Nov 22, 2014 | Toro Garden
How to fix a leaky Toro 20007 fuel tank
If the fuel tank is metal take it off and clean the seam with sandpaper and use JB weld to repair it- If plastic tank, use a glue gun.
Apr 18, 2014 | Toro Lawn Mower With Toro Power Tools
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
Gas leaking under tank
Remove and replace fuel line from tank to carb. Ensure fuel tank is not cracked on bottom. Replace fuel line clamp on tank.
Jun 08, 2012 | Toro Power Lawn Mower
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Toro TimeCutter z4200 will not start
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
Apr 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
