Question about Microwave Ovens
Toshiba Microwave Oven Model ER-A7C(S) with H68 error code, Please guiding what the problem is and how to solve or repair
    Top Expert:
  • Microwave Ovens Master
  • 26,668 Answers
Replace the inverter board and use a qualified microwave engineer. There are extremely dangerous voltages in here!
Posted on Nov 22, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jun 08, 2008
SOURCE: Toshiba ER-684 microwave time setting?
clock - clear - enter time - clock
Posted on Jun 20, 2009
  • 327 Answers
SOURCE: 66993 pizza oven microwave oven combo
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Posted on Jul 13, 2010
espressonist
  • 1711 Answers
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Posted on Nov 04, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
How do i start a toshiba model er-555btc microwave oven
Have you tried Manuals on line and the manufacturer?
Feb 18, 2015 | Microwave Ovens
What is Error F7
I am having the same problem. According to the owner's repair guide error Code F7 indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
While this is helpful, it is still out of my confort zone as I pulled the control panel and discovered a virtual zoo of connectors. Obviously ponly a trained repairman knows which ones need to be checked. I will probably have to resort to calling one and shelling out the dough.
Jun 21, 2013 | KitchenAid KHHS179LSS Convection /...
I need a toshiba microwave oven er-9610 operators manual
You can visit their site to see if available from Toshiba or GOOGLE THE FULL MODEL NUMBER WITH "MANUAL"
Dec 17, 2012 | Microwave Ovens
Toshiba microwave model er-7800ew what litre is it
Hi. I have had the ER-7800EW m/w since October 1986 and, yes, it still works. I also still have the Owners's Guide Book.
It's internal cavity volume is 27 litres and, in case it is your next question, its power is 650 watts. (Nothing like 1200 watts like someone said).
I will scan and upload the User Guide if I can.
Apr 03, 2012 | Microwave Ovens
My Kenmore Elite will not heat has F-9 on display
Hello :
F-9 error code indicates a defective control board, inverter module or line voltage too high You can try unplugging or disconnecting the electrical power to the unit for at least 50 seconds to see if this solves the problem, if not then I recommend to replace the inverter module, if this does not solve the problem then the control board will have to be replaced. If that didn't solve the problem , then call for repair .
I hope this will help .
Please rate !
Mar 27, 2010 | Kenmore 64683 Microwave Oven
F-9 Error Code and Note heating
Hello :
good luck .
rate please !
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
4. Check cooling fan operation
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Code F6
That's usually failure of a relay on the control board.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
Oct 22, 2008 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
122 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
