Question about Champion 3500/4000 Watt Portable Generator
My genorator wont star in cold weather - Champion 3500/4000 Watt Portable Generator
    Top Expert:
  • 23,659 Answers
Petrol or diesel?
Posted on Nov 22, 2014
My 1989 honda gl 1500 gold wing wont start in cold weather, it cranks over
Mine does the same thing. I put a new gel battery with high cold cranking amps from Advanced Auto Parts. Look to spend 100 bucks. Choke at full choke and it starts right up now. Gold Wings are cold natured. I own 2 and both are. But the battery took care of the cold starts.
Jan 11, 2013 | 1989 Honda GL 1500 Gold Wing
2006 nissan navara wont start in cold weather
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
2005 yamaha royal star. what type and how much oil for the tranny?
The Royal Star crankcase lubricates engine, transmission and wet clutch at the same time, that's why frequent oil and filter changes are recommended. Use a high-quality multi-grade oil, 10W-30 in cold weather and 20W-40 in hot weather is recommended by the manufacturer. AVOID ANY OIL THAT SAYS ENERGY-CONSERVING (you'll see a seal on the bottle), that type of oil has a tendency to make the clutch slip. Personally, I recommend a multi-grade synthetic - I use Shell Rotella-T (T6) synthetic 5W-40 year-round, 111,000 miles since I changed from Mobil-1 0W-40 (9,000 on the Mobil-1) ; the engine's still tight, and the transmission and clutch are quiet.
Jun 09, 2010 | 2005 Yamaha Royal Star Tour Deluxe
Car stars, will run for 10 seconds then cuts out.
check your mafs it may be dirty clean it with mafs cleaner
Jan 08, 2010 | 2006 Nissan Xterra
Jag wont start in cold weather
changed the battery, now it starts right up and no fault lights!
Jan 06, 2010 | 2005 Jaguar XJ-Series
Car wont start in cold weather...think it may be
Will it start with a boost? Have you had battery fully charged and load tested? Battery tested at a garage, or autoparts stores, are usually free.
Nov 16, 2009 | 1983 Plymouth Turismo
Nissan max. 1995 wont start during cold weather
I had the same problem for years until I cleaned the throttle body, Complete instructions can be found here http://www.motorvate.ca/mvp.php/517. It's easy and it worked for me. Good luck.
Sam
Feb 25, 2009 | 1995 Nissan Maxima
Ford thunderbird wont start in Cold weather
change distributor cap first and see how it goes could have a crack in it.Failing which you need to test the ignition module when its cold as sometimes a component will break down and not work when its cold ,this is very much a hands on type job so if dist cap doesnt cure it call a mobile mechanic
Jan 27, 2009 | 1997 Ford Thunderbird LX
97 taurus will not star in cold weather
I had this problem with my 98 taurus i tried jumping it wouldn't start, mine was the fuel pump check.
Jan 14, 2009 | 1996 Ford Taurus
1994 ford aerostar wont start in -30 c weather but ran fine day b
Have u tried 2 get it winterized. changing all fluids,like the antifreeze,and all the other fluids.
Dec 15, 2008 | 1997 Dodge Caravan
Champion 3500/4000 Watt Portable Generator Logo
148 people viewed this question
Top Champion Televison & Video Experts
bobalix
Joseph Hoffmann
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
