Question about Samsung S1070 Digital Camera
Lens keeps sticking and turning straight off. Have tried new batteries but not helping. Just turns straight off.
I have changed the batteries but do not know what else to do.
How do I change the bulb in the door mirror on a Volvo S80 2004
If it's the approach light under the mirror, the lens pops out to replace the bulb. If it's the turn signal bulb, then the mirror cover has to come off
Feb 16, 2015 | 2004 Volvo S80
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Olympus FE360, When I turn it on the lens zooms out and straight back in and turns itself off - please help
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Works also on Olympus canon and all cameras of this type so stick with it!
Please rate our help to keep the service online
Oct 11, 2009 | Cameras
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Sony DSC W100 lens is stuck
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Aug 16, 2009 | Sony Cameras
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Camera won't turn on
try replacing the battery, could be the camera, it could just be a defective battery or lens or camera
Feb 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
CAMARA turns off when i press to take a photo
I have the same camera... and it was doing the same thing AFTER i changed my old batteries, because they were getting low. It was only after i put in the NEW batteries that i had this problem... I tried putting the old batteries back in and sure enough it worked again, so it probably all just depends on the brand of the battery you use.
Oct 09, 2007 | Fuji FinePix A500 Digital Camera
Camera sticks and screen won't stay on
I sent mine back to be serviced and they said it was the batteries. Use rechargables fully charged.
Nov 19, 2006 | Polaroid i532 Digital Camera
Samsung S1070 Digital Camera Logo
44 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
