Question about Garden
Where is primer bulb - Garden
  • 603 Answers
Not every small engine has a primer bulb. But you can look on your carburetor and if you have a primer bulb you will see a plastic dome shaped bubble that if you press on it you will feel slight pressure of gas pushing up into carb. These primer bulbs help to start engines quicker. GOOD LUCK FRIEND.
Posted on Nov 22, 2014
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
Replaced te fuel lines. no sure Ihavethe lines connected properly
Not sure if your primer bulb is on the carb or separate but here are some basics... The smaller line is the main fuel line. It has the fuel filter on it and the filter should be laying on the bottom of the tank. That line goes to the fuel pump side of the carb ( usually the inlet near the center of the carb body ). The fuel goes through the filter up the main line and fills the carb then to the primer bulb whether its on the carb or separate. If on the carb the spigot closest to the primer bulb takes the larger line and returns to the tank. That line should go into the tank about half an inch and terminate. If the primer is separate the larger line leave the carb from the spigot on the metering side ( usually close to the edge of the carb body) to the inlet of the primer bulb then from the primer bulb out ( usually center of the bulb) to the tank and terminates about half an inch inside the tank. Remember... fuel filter into carb, carb to primer bulb, primer bulb to tank. If the fuel does not go that direction when the bulb is primed then you have lines hooked up backwards.
Aug 03, 2014 | Ryobi Garden
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Jul 23, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Stihl chainsaw primer bulb will not fill. Puts pressure in fuel tank
try switching the tubes on the back of the primer bulb
Nov 12, 2013 | Stihl Garden
Is the primer bulb necessary?
I dont think you should do that since the primer bulb is what gives gas to the carb, on most models.
Jul 28, 2012 | Ryobi Garden
Otmail.com Buble thing at carburator has stuck in and will not come back out any advice
I believe that your question is in reference to the primer button on your carburator. If this is so and your button is pushed in then you will have to change the button. Take a pair of needlenose pliers and pull out the damaged primer bulb. Then go in with a pick tool and pull out the ring that is seated in the carburator at the bottom of the primer bulb. With the old primer bulb out of the carburator you can now install the new primer bulb. Put new primer bulb into place and with a dull punch slowly and very carefully seat the new primer bulb. This should put you back in business again. GOOD LUCK.
Jul 05, 2011 | Briggs & Stratton Garden
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
The primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Jul 18, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
