Question about Samsung S1070 Digital Camera
The lens is sticking and turning straight off. New batteries in so do not know why
New batteries do not know what else to try?
How do I change the bulb in the door mirror on a Volvo S80 2004
If it's the approach light under the mirror, the lens pops out to replace the bulb. If it's the turn signal bulb, then the mirror cover has to come off
Feb 16, 2015 | 2004 Volvo S80
Won't turn on despite new batteries fitted correctly. The camera was bought in 2008 and only used a few times but now it won't turn oni've put brand new Duracell batteries in it and when you turn it on the...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 09, 2010 | Sanyo Xacti S650 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Samsung Model S630 Lens will not retract into camera.
Remove the battery and insert new battery and check if it is working .
If it is not working then you gently tap on the sides of camera this will work .
Oct 20, 2008 | Cameras
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Lens Error
Two posibilities : either the gear box needs attention or the lens itself is impacted . The first problem is not so expensive to sort out by your repair outfit but the impacted lens problem is expensive ( may require replacing lens assy. ). Anyway camera has to go in I am affraid.
Aug 24, 2007 | Kodak EasyShare C643 Digital Camera
Camera will not start properly and lens is out
Leave the camera sitting with no batteries overnight. Then in the morning install ONLY Kodak AA batteries. I had the exact same problem.
Jun 22, 2006 | Kodak EasyShare CX7330 Digital Camera
Samsung S1070 Digital Camera Logo
54 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
