Question about Jeep 2005 Grand Cherokee Laredo
How tight should the head on a 05 cherokee laredo 3.7lt engine be?
    Top Expert:
  • Jeep Master
  • 25,744 Answers
Usually between 105 and 115lb/ft
Posted on Nov 22, 2014
  • 512 Answers
SOURCE: Head Bolt Torque for a 2000 Grand Cherokee Laredo 4.0L
the torque is a 4 step process
1 torque all bolts to 22 ft/lbs
2 torque all bolts to 45 ft/lbs
3 recheck all bolts to 45 ft/lbs
4 torque bolts 1 thru 10 to 110 ft/lbs
bolt 11 to 100 ft/lbs
bolts 12 thru 14 to 110 ft/lbs
bolt #1 is the fourth bolt from the front on the passenger side....#2 is the fourth bolt on the drivers side then you continue in a clockwise order
Posted on Jan 04, 2009
  • 6982 Answers
SOURCE: I'm replacing my rear rotors on a 2005 grand
check with a parts house and see if both vehicles have the same part # for rear rotors. If they do you will be fine. Don't try "adapting" stuff in brake systems...It's difficult and dangerous. Rotors even new are not that expensive!
Posted on Mar 17, 2009
SOURCE: Will a engine from a 2003 jeep grand cherokee
yes it will
Posted on Jan 07, 2010
  • 6982 Answers
SOURCE: how to check/change fuse on '05 jeep grand
You can check fuses easily by using a test light. Turn the key on and probe the small openings at the fuse ends. You should have power at all except one that is for the headlights. You can easily remove any faulty ones by grabbing it with a small pair of needle nose pliers. they pull right out and easily push back in place.
Posted on Jan 26, 2010
  • 6982 Answers
SOURCE: Would a 2001 Jeep Grand Cherokee Laredo engine fit...
The actual engine assembly will fit but you need to determine if there were any changes made between the two years in the computer or wiring harness. Also make sure that both engines have the exact same transmissions as sometimes the bellhousing patterns are different.
I'm pretty sure yours is a direct replacement though, providing both engines are the same displacement..Most scrapyards have an interchange manual that may help you. (they have to know these things...it's their business)
Posted on May 15, 2010
2000 jeep grand cherokee' recently had the head replaced, is it normal to use a little coolant each month.
A sealed system should be that. Either the coolant is overheating and steaming out through the reservoir, or more worryingly, the new head gasket is leaking. That is assuming they used a new gasket and sealant.
May 10, 2015 | 2000 Jeep Grand Cherokee Laredo
Replacing sparkplugs in Jeep 2004 Grand Cherokee Laredo
no engine size stated, so how could we be specific?
how to? try forming a real question? is that hard?
how to do it with my hands, or who can. (any shop can)
or what tools needed?
what parts.?
what gap.?
what are things to avoid, (stripping them out) stripping head.
why not use youtube do it to say 10 cars.
read the manual yet, the fsm.
see 05 here.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
read spark pages.
Feb 22, 2015 | Jeep Grand Cherokee Cars & Trucks
I have a 05 jeep grand Cherokee Laredo 4*4 when im taking off I get a clucking noise coming from the middle of the car
Check the universal joints on the drive shaft. You can do this by sliding under the car and move the drive shaft by hand. If there is a lot of movement before it can no longer be turned then it's likely the jionts need replacing.
Feb 08, 2015 | Jeep 2005 Grand Cherokee Laredo
Interchange
ask dealer or junkyards.
Feb 24, 2014 | Jeep 2001 Grand Cherokee Laredo
My lifters are loud on my Grand Cherokee Laredo 4.0 engine and I tried Lucas about 3weeks ago, still making the noise. Actually it sounds a little louder than before can you help me-on a very tight budget!
I had the same problem on my 02 Grand Cherokee the truck was still under warranty and the dealer replaced all the rockers and problem was solved.
Sep 16, 2011 | 1999 Jeep Grand Cherokee
Should i use synthetic oil on my 05 Grand Cherokee Laredo instead of conventional?
I would only use synthetic oil if there is a sticker on the engine compartment or the manual says that it is recommended.
I would use conventional oil unless otherwise specified.
Just have it changed every 3,000 mi. along with the filter and lube.
Sep 15, 2010 | 2005 Jeep Grand Cherokee
I have a 1996 Jeep Grand Cherokee laredo. I am trying to find the coolant temp sender that is on the back of the block. Is anyone able to tell me where this is exactly? From what I have heard, there are 2...
if this has the 4.0 ltr, it is on the rear corner of the head near the corner of the valve cover,it screws straight down into the head and is actually a very small and slender sensor,and has a one wire connector and i believe the sensor connector is white,but the wiring connector that goes to it is black if i remember correctly,hope this helps
Sep 11, 2009 | 1996 Jeep Grand Cherokee
I'm replacing my rear rotors on a 2005 grand Cherokee Laredo. I just want to know if the 05 grand Cherokee Laredo has loose fitting rear rotors or will I have to pull it as an assembly, consequently having...
Mar 17, 2009 | 2005 Jeep Grand Cherokee
Jeep 2005 Grand Cherokee Laredo Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
