Question about Garden
Are the two rear plugs that holds the rear draft link support pin in threaded or just drove in on my John Deere 4520 tractor?
  • 95 Answers
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
A serpentine belt diagram for a John Deere 4520 tractor please
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 4520
Apr 29, 2017 | John Deere Garden
How to I remove the steering wheel from SX75 John Deere riding lawn mower
I have not been able to pin down your exact model but this link is to another model that may give you the info you need. john deere 214 steering wheel removal
Oct 17, 2016 | John Deere Garden
Low hydraulic pressure to raise implements 8650 john deere
Could be the charge lube in the rear differential. It supplies oil to main Hydraulic pump up front on engine. The charge pump drive can strip and not turn pump. To remove pump drive remove third link plate on rear frame, remove plug behind plate, pull out hex shaft, about 5 foot long and inspect.
Oct 01, 2016 | John Deere Garden
How do you set the valves on a 2005 john deere 4520 tractor?
Repair your vehicle right away. Just click on the link I attach.
Best Manuals
Nov 22, 2015 | John Deere Garden
Err 68 what it means and how too fix no fule too motor
Err 68 means
Err 68 Hold-in Relay ON. Output from the Display is short circuit. No fuel to the engine. Contact your John Deere dealer
Aug 24, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
How to hold btushes in to put on rotor
I tie the brushes in using threads then cut and remove the threads after it is assembled.
This assumes there is gaps to get in after the assembly. If there none there should be 2 small holes in the housing that allow pins or very small rods to be inserted past the brush when it is fully depressed holding it in its holder. The pins are removed after assembly letting the brushes seat.
Aug 19, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
I have john deer sabre 18 horse i have a snow blade but cant get on right
My name is Dane and I'll try to help you with your problem. I have given you the basic instructions here for mounting most john deere snow blades.
Here is a link to the parts diagram for the blade too.
http://www.searspartsdirect.com/partsdirect/part-model/Sabre-john-deere-Parts/Riding-mower-tractor-Parts/Model-15538G/1828/1509200/10060752/00034
You need to remove the mower deck from the machine, and you may have to remove the front bumper as well.
First, install the mounting brackets on the tractor. Align the holes in each mounting bracket with the holes in the tractor frame. Install using the kit that comes with the mounting bracket. Don't tighten this yet.
Next you should install the pivot support. Insert the pins on the right and left hitch plates into the notches on the mounting brackets. Install the pins and tighten the screws on those mounting brackets now.
Next you should Install the blade. Align the holes in the pivot support with the second holes from the end of the push channel assembly. Insert the channel pin and washer and secure with the spring locking pin.
Install the lift handle. Slide the lift handle rod into the end hole in the push channel assembly. Insert the lift link pin in the pivot support bracket into the lift handle rod. Add the washers and locking pin.
Now, Iistall the blade pivot rod. Either end of the blade pivot rod goes through the blade pivot shaft. The other end goes through the lift handle tube. Secure both ends with locking pins.
Lubricate the lift handle rods and pivot points.
Install the rear tire chains and wheel weights.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thanks! Dane
Dec 03, 2010 | John Deere Garden
Are the bolts on a John Deere F715 blade right or left hand threads
The bolts that hold the blad on are left hand thread.
Good luck and please rate 4 thumbs up for the free answer.
Jul 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Need Sevice and repair manual for a 6400 john deer
Please email dcooper5126@yahoo.com. I would like to copy your technical and operators manuals, mine i think my x swiped, i really need them,,,,,,thx
miss delynda
Sep 18, 2009 | John Deere Tractor Side Screen...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
