I have a whirlpool awo/d8140 washing machine that has suddenly seems no power. I have changed the fuse tested the plug and socket and nothing apears untoward when taken the lid off. Any ideas? Cheers Neil
    Scholar:
  • 91 Answers
If there is power to the main board, would suspect the board is the issue, however, if the pump, motor , water solenoid ect has a fault, machine will not fire up
Posted on Nov 27, 2014
jonniewalker
  • 1031 Answers
SOURCE: fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Posted on Jan 29, 2009
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
  • 86 Answers
SOURCE: cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Posted on Feb 27, 2009
  • 12 Answers
SOURCE: Can you please help me, i need a users manual for Washing machine
download from whirlpool.com
Posted on Mar 27, 2009
reddyanantha
  • 205 Answers
SOURCE: i need to clen the pump on a whirlpool washing
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Posted on Sep 22, 2009
Testimonial: "cheers man , great help prob solved. "
AWO/D4405 whirlpool washing machine has power to machine but nothing lights up or works ?
all washers have a switch without them the washer would cease to operate. Check power source (outlet at the wall. ) use bed light lamp to test. if thats ok you may have a a faulty switch or an internal safety fuse blown
Jan 31, 2015 | Whirlpool Washing Machines
MY WHIRLPOOL WASHING MACHINE AWO/R5206 CONTROLS ARE NOT LIGHTING UP AT ALL. CHECKED FUSE IN PLUG AND FUSE BOARD NOTHING WRONG.
I am sure there is a electronic control board on the machine. I will bet the control board is defective.
Nov 26, 2014 | Whirlpool Washing Machines
No power to Whirlpool awo/d5727. I have checked the fuse and the socket but still have no power.
You say you checked "socket" and the "fuse," did you mean the AC wall outlet (115V) and a fuse or breaker in the main power panel?
Nearly all circuits involving water are protected by a Ground Fault Interrupter that can be servicing several wall outlets (perhaps one not near the washing machine) or can be located as part of a circuit breaker in your main power panel.
The GFI outlets will have one or two push buttons located between the outlets and a combination GFI/overcurrent breaker will also have at least one button where others will have none.
If you find one that is tripped, try resetting it. If it will not reset, unplug the washing machine and try again.
If it now stays on, your machine may have an electrical path causing it to trip and using an unprotected outlet may be unsafe and an indication that the appliance itself may have electrical leakage which could be otherwise dangerous.
The circuit breakers in the main power panel can also fail (they didn't 20 years ago) and we have replaced 3 in a home only 5 years old already so they are not made well anymore.
Jun 22, 2013 | Whirlpool Washing Machines
I have a Whirlpool AWO/ 41628. That refuses to power up and has no power indication on its control panel
Try reseating the wires under the control panel. Fully disconnect plastic connectors, inspect the ends, reconnect. Individual wires that don't readily pull from their connections should just be wiggled. Reseat what you can and wiggle the rest; don't break anything. If still nothing inspect the control panel for burnt resisters or swollen capacitors. If it looks good let me know.
Jan 30, 2013 | Whirlpool Washing Machines
No power in whirlpool washing machine
hi mine did somthing similar not sure what the part is called but it looks like a silver battery thing about 4 inches long about 2 inches around with a few wires comming out of it mine blew this and the house fuse couldent miss mine as it was black changed this and it was ok hope this helps ivan
Sep 25, 2012 | Whirlpool Washing Machines
AWO 3551 have a FP fault . help
thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
Feb 21, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Whirlpool AWOE 8748 has no power. Changed fuse and tried in a different socket. Still no power.
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
