Question about Building Materials
What causes error code14
Madeure eye sensor lined up onlywhen its cold
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
Check owners manual for list of troubleshooting codes should be available on line as well
Posted on Nov 30, 2014
Recently installed a Noritz NRCP 112 water heater, but very frequently it keeps shutting off and on the display it says error 60, after looking at the manual there is no explanation of what error 60 is....
Shut downs with new heater might be defective PC board.
Other issues could be associated with improper installation.
Low gas pressure caused by undersized gas meter or water in the gas line, undersized gas line to unit (requires 1" gas line to within 10 feet and then 3/4"), wrong type of gas line (cannot use flexible gas line), improper vent (for example too long horizontal run or undersized vent pipe or shared vent with furnace or other gas appliance), not enough incoming fresh air supply, nearby exhaust fans or vent fans stopping proper draft on tankless, temperature set too high for cold incoming water supply (install tempering tank to help preheat water),..
http://waterheatertimer.org/Tempering-tank.html
Other causes can be clogged water filter located where cold water enters tankless, or clogged water line, or crossover caused by bad single-handled faucet or bad crossover valve on recirculation system, improperly sized recirculation system. These problems can mean less water flow through tankless, so burner shuts down, and unit throws error code because sensor indicates water flow is still moving but inadequate to trigger burner
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Gene
Water Heater Timers Save Money
Nov 27, 2014 | Water Heaters
Tip
Bad fuel economy and lumpy idling - possibly causes
<p><b><u><span>Excessive fuel consumption and 'lumpy' idling engine</span></u></b><br /> <p><b><span>Possible faults:-</span></b><br /> <p><b><u><br /></u></b><br /> <p><b><u><span>Coolant sensor </span></u></b><span><span> </span>- engine is signaled as being 'cold' all the time, not just at start up, causing ECU to set longer injection cycle </span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Low coolant level can prevent sensor being able to detect coolant temperature</span><br /> <p><span><span>&oslash;<span> </span></span></span><span>Faulty 'open' thermostat allows coolant to circulate without regulation and perhaps prevents the engine from achieving normal running temperatures.</span><br /> <p><span> </span><br /> <p><b><u><span>FPR</span></u></b><span> - broken diaphragm allows fuel to enter the vacuum line and then into the inlet manifold. Additional source of fuel makes the fuel air mix richer causing a faster and lumpy idle.</span><br /> <p><span> </span><br /> <p><b><u><span>Vacuum leak </span></u></b><span>- 'high oxygen' signal from O2 sensor causes ECU to set longer injection cycle.</span><br /> <p><span> </span><br /> <p><b><u><span>O2 sensor</span></u></b><span> - 'high oxygen' sensor error causes ECU to set longer fuel injection cycle</span><br /> <p><span> </span><br /> <p><b><u><span>MAF</span></u></b><span> - 'over reads' in error the amount of air entering causing ECU to set longer fuel injection cycle </span><br /> <p><span> </span><br /> <p><b><u><span>IAT</span></u></b><span> - 'under reads' in error the temperature of incoming air causing ECU to set longer fuel injection cycle</span><br /> <p><span> </span><br />
on Jul 22, 2011 | Mercedes-Benz E-Class Cars & Trucks
9.31 precor error 26 and loud noise
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Dec 16, 2013 | Exercise & Fitness
Yahoo mail Temporary code14
Error Code 14 are caused by misconfiguration of system files.
Error Code 14 Problems usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
The Error Code 14 are easy to repair. By downloading and running a registry repair tool, you can quickly and effectively fix this problem and prevent others from occurring.
I recommend Advanced System Care. It works and it is free!
Oct 25, 2013 | Dell Inspiron Computers & Internet
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
My 2000 Grand Prix GTP runs great. However, the gas mileage has dropped to maybe 120-130 miles per tank and at idle there is a very strong odor of gas inside and around the car..noticed no drips on...
Following list of possible faults should help:-
Coolant sensor - engine is signaled as being 'cold' all the time, not just at start up, causing ECU to set longer injection cycle
? Low coolant level can prevent sensor being able to detect coolant temperature
? Faulty 'open' thermostat allows coolant to circulate without regulation and perhaps prevents the engine from achieving normal running temperatures.
FPR - broken diaphragm allows fuel to enter the vacuum line and then into the inlet manifold. Additional source of fuel makes the fuel air mix richer causing a faster and lumpy idle.
Vacuum leak - 'high oxygen' signal from O2 sensor causes ECU to set longer injection cycle.
O2 sensor - 'high oxygen' sensor error causes ECU to set longer fuel injection cycle
MAF - 'over reads' in error the amount of air entering causing ECU to set longer fuel injection cycle
IAT - 'under reads' in error the temperature of incoming air causing ECU to set longer fuel injection cycle
May 10, 2011 | Pontiac Grand Prix Cars & Trucks
Iphone dont want to restore and it give me error code14
you will have to restore it mate for it to solve the problem itself make sure you back it up though
Feb 06, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Ideling 1600 rpm onlywhen engine warm
please change the idling switch control valve assembly plus the sensor!
Jun 18, 2009 | Mercedes-Benz SL-Class Cars & Trucks
Building Materials Logo
77 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
