Question about Garden
My echo pb250 leaf blower wont start - Garden
  • 63 Answers
The first thing that I must ask is, "Did you store your blower with gas in your fuel tank? If so, your carburetor will have to be rebuilt because the fuel breaks down the diaphragms and cloggs the screen inside the carburetor. If you didn't store your blower with fuel in the tank then pull the spark plug to see if it's firing. If you have fire the you have to check the compression because you need at least 95psi in order for your blower to run.
Posted on Nov 26, 2014
  • Jimmy Dominguez
    Jimmy Dominguez Nov 28, 2014
    I did store with fuel in it all the time,recently with out oil mixed n it ran several times then just one day didnt start.i sprayed wd40 in hole of spark plug.when i pull cord piston moves but dont start up still.thank u for advice n ill do what u suggest i appreciat . It alot that u took time to help me out sir.
4 Suggested Answers
  • 122 Answers
SOURCE: my echo backpack leaf blower
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Posted on Aug 30, 2011
2strokeJim
  • 577 Answers
SOURCE: I have a new echo
sounds like a dirty carb, dissamble it and rinse good with carb clean, be careful when taking the top off it that you get it back together the same spray the white center good and all little holes good. then reassemble, also try to loosen your gas cap maybe first before cleaning carb, you might have a plugged vent in the line coming out of the tank. Good Luck
Posted on Apr 05, 2011
  • 7 Answers
SOURCE: Blower starts and runs for
I don't think the oil-gas ratio will cause that problem. Did you check to see if the fuel lines or fuel filter is clogged?
Posted on Aug 15, 2011
Echo pb250 blower how to adjust carb.
the new carburators do have adjustments but consumer is not allowed to adjust do to epa regulations find an echo dealer or echo repair tech with tools to do job everyones answer is carb clean carb clean damages diaphrams and seals in carb never use carb clean on lawn and garden equipment.
Jan 07, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
Echo blower wont fire
you sheared the flywheel key... If it's a PB250 251 or something along those lines you are going to need a new carb and flywheel. Take it to the dealer and see if they can fix in under warranty... Why the carb you say, it leaked causing the flywheel to come loose. If it's not under warranty then do not repair, you can buy a new one for about $160 USD
Dec 24, 2013 | ECHO, Inc. PB-251C Handheld Blower
Echo pb-251 won't run with out choke
I would say that Daren is on the best track here for repair. Myself i agree with the fact that your carb has some sort of blockage. Start with a good carb cleaning. Good Luck....
Nov 11, 2013 | Echo Gas Blower 135 MPH390 CFM Blower...
How do I clean a float needle seat on Echo blower?
pull carb off, dissemble it and replace needle and diaphram (carb kit) and clean it thourghly and then also make sure your tank vent is working properly cause if not it will drain your fuel tank also and fill your crankcase and cylinder with fuel !
May 17, 2012 | Echo Gas Blower 135 MPH390 CFM Blower...
Blower starts and runs for 5 seconds and cuts off. Is it an oil to gas ratio. Is is 32:1 or 40:1? For the Echo PB250 gas blower.
Aug 15, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have an echo pb400e backpack blower. it wont start. getting fire but wont crank.
is your spark plug getting wet from fuel? try take air snorkel off carb and give it a shot of carb cleaner if it fires you have a fuel problem if it doesent fire , and plug is wet pull plug and rollover and get excess fuel out of cylinder, and try carb cleaner again, if no luck check compression, then if good go to flywheel and see if loose
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Only three months old and used twice now it won't start we chnaged the gas brand new with new mixture. It boggs and just dies. ECHO PB250
My research shows that a consumer gets a 5 year warranty and a commercial user gets a 2 year warranty on any Echo equipment they buy. Could you consider getting some warranty service on this unit since it is still under coverage? It sounds like a fuel delivery problem (carburetor adjustment maybe), but I also realize that some of the newer "rotary" type carburetors in use don't have the Low and High speed mixture adjusting screws like the old-style diaphragm carburetors that preceded them.
Jan 30, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Echo leaf blower..cranks fine, idles fine, will not throttle up.
Sounds like restricted exaust. Remove the muffler and start it, see if that fixes it. If yes clean remaining carbon from exaust port. And clean spark arestor screen.
Nov 03, 2010 | Echo Gas Blower 135 MPH390 CFM Blower...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
