Question about Nespresso Coffee Makers & Espresso Machines
How to fix this problem with my Nespresso Pixie: made one cup of coffee. When I tried to make a second, the water started coming out of the bottom of the machine and the pod was not pierced on top to
Unplugged and replugged the machine. Try running it without pod. Tried running it to remove all water. Added water back in, added pod, and water still came out of the bottom of the machine. Rubber banded the pod.
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
NiftyInsight
  • 15 Answers
SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
Posted on Feb 21, 2010
tgmusicgirl
  • 92 Answers
SOURCE: The water will not go through the pod to make the coffee
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
Posted on May 18, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: been using the B30 for
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
sdf
sd
fdsf
s
f
Posted on Dec 22, 2010
heatman101
  • 43501 Answers
SOURCE: water does not go through the k cup. when the cup
Yup... the bottom needle is plugged...Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 25, 2011
Nespresso C60 not work
DO YOU HAVE LIGHT OF SOME KIND IS THERE ANY POWER INDICATOR ?
Nov 12, 2015 | Nespresso Pixie C60 Single Cup Espresso...
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
Nespresso pixie c60 only brews for a few seconds on full cup mode
Would love more info, like how long did you have this item and did it go from 10 seconds to 3 seconds with less water over a period of time or just over night?
if this has been giving you less and less water and taking / shorting the amount of time you might have Calcium build up inside the unit that is not that easy to clean out, Seen it happen on a mr coffee unit it would make a 1/2 pot of coffee because of the build up from the hard water in the area.. Needed a new coffee maker.
Dec 09, 2014 | Nespresso Pixie C60 Espresso Maker...
I have a Pixie but the large cup does not shut off
Hold both buttons down while you turn the machine on - for 5 seconds - which will reset the machine to its factory settings. Then you can reprogramme to suit your taste, as in the instruction book. Good luck - hope this helps.
May 27, 2014 | Nespresso Le Cube
Grounds in cup
what is you primery foult what is the model does the coffee goes in the waist?
Sep 01, 2017 | Nespresso Coffee Makers & Espresso...
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
