Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
My PC's Fan has a loud humming sound every time I boot up PC, how do I fix that?
The following is what I have tried : I have tried cleaning my computer's fan I have tried cleaning my computer's tower I have tried calling up a few repair shops that had no idea! I have tried unplugging everything and re - hooking it up.
  • 20 Answers
Hi.
As Dean said, if the humming noise is always present even with the fan spinning at low RPM, replace it. If it's only loud when booting it might be normal ; some computer's BIOS spin the fan very fast when booting and when the Operating system or preset parameters take over, they gradually lower the speed. By the way, unplug the fans one at a time to find which one is causing the noise. If it is a case fan they cost only a few bucks, if it is the CPU fan it is a bit more expensive but aftermarket cooler can be found for around 20$. If you need to replace the CPU cooler, make sure you clean the old thermal paste and apply some fresh one. For a tutorial how Youtube is your best friends ;)
Posted on Nov 22, 2014
    Problem Solver:
  • 14 Answers
The fan is a cheap "bushing" fan and there is no repair once the bushings go. The only "fix" is to replace the fan. Sorry, but it's your only option.
dean
2 Suggested Answers
Scott Ellin
  • 558 Answers
SOURCE: PC SHUTS DOWN MONITOR AND FAN
Hi Brandy19960,
Thanks for the posting in FIXYA.
Please do the following steps:
Step – 1
Right-click on My Computer, open Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” Uncheck the box in front of “Automatically restart.”
Step - 2
To change the setting, click Start --> Run--> type GPEDIT.MSC, click OK.
Drill down to Computer Configuration | Windows Settings | Security Settings | Local Policies | Security Options.
In the right pane, find “Shutdown: Clear Virtual Memory Pagefile.”
NOTE: Since someone actually has to have set this policy, the problem will be pretty rare, but is worth mentioning. However, Forum participant “roadrunner” reported that the personal security app Privacy Eraser automatically enables “Clear virtual memory pagefile,” and, therefore, may be the cause of a slow shutdown.
Step - 3
When Windows XP won’t powerdown automatically, the APM/NT Legacy Power Node may not be enabled. To enable this, right-click on the My Computer icon, click Properties | Hardware | Device Manager | View. Check the box labeled “Show Hidden Devices.” If it’s available on your computer, there will be a red X on the APM/NT Legacy Node. Try enabling it and see if this resolves the powerdown problem (Tip from Terri Stratton). Or, to check the other side of the APM/ACPI coin, open the Power Options applet in Control Panel. If there is an APM tab, make sure the “Enable Advanced Power Management Support” box is checked.
Step - 4
Try a Shutdown shortcut -
For a shortcut to RESTART Windows XP:
SHUTDOWN -r -t 01
For a shortcut to SHUT DOWN Windows XP:
SHUTDOWN -s -t 01
Step 5
WORK-AROUND: Disable power management for your USB hub: Open Device Manager (click Start, click Run, type DEVMGMT.MSC, click OK). Double-click to expand Universal Serial Bus Controllers. Double-click USB Root Hub. Click Power Management. Uncheck the box “Allow the computer to turn off this device to save power.” OK your way out
Step – 6
Click on the Start button.
Select Run from the menu.
In the run dialog box type “msconfig”.
Click OK.
Once in the msconfig utility select the startup tab. In the startup tab you will see several programs listed with a checkbox beside it. If there is a check mark beside the application listed, the application will startup when your computer starts up.
Regards
ELLIN
Posted on Sep 13, 2008
There is humming sound coming from the computer and the green light below the power buttom is flashing.
You didn't list the make and model, what is this light for? Power light, cd drive, etc...
Jul 08, 2008 | Computers & Internet
Compaq presario sr1420nx fan noise
Just replace the fan. They are a standard commodity and not hard to change. Get a good one this time. You get what you pay for.
Feb 14, 2008 | HP Compaq Presario SR1420nx...
Program button no response
The cd shouldn't be making a noise, but your cd drive might be, there could be something wrong with it try to identify any cracks or marks on the cd, if there are any that may be the cause behind the program not responding. The loud hum you're hearing could be due to overheating, carefully check your computers temperature, if the cd is damage the loud hum may be produced due to the cd drive overworking itself trying to read a damaged disc. Hope this helps.
Feb 12, 2013 | Computers & Internet
Loud grinding or humming noise
It sounds like you have a fan with a bunch of gunk on it. Get a can of compressed air and clean out all the vents and fans.
Also, take a close look at your video card's fan. It might be the culprit. Many times when they are about to die they make a lot of noise...
Jul 27, 2012 | eMachines Computers & Internet
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
My Acer Aspire One AOA150 's fan is very loud and warm
I'd suggest that you carefully pull the base of your Acer apart - taking out the screw, and keeping track of them. See if your fan is dirty - I have an Acer as well, and if it's dirty, it get loud, and HOT!
A quick cleaning does wonders!
Feb 15, 2010 | Acer Aspire One AOA150-1784 Netbook
Loud cooling fan hum
If the fan was not that noisy before , this can only be cause by a dirty fan and you may need to clean it up to reduce the hum coming out from it...
Dec 28, 2008 | Acer Extensa Laptop
Kirland Refrigerator
It sounds like your compressor has failed. The hum is the compressor trying to start and the click following is the over current protector opening.
Jun 16, 2008 | Refrigerators
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
322 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
