Question about Cuisinart Custom Pro 11-Cup Stainless Steel Food Processor EV-11PC7 OPEN
The top of my new food processor won't lock into place. It goes so far and no more. Will not operate I til it s locked. I am using lots of strength and don't want to break it.
Reading instruction manual several times
  • Cuisinart Master
  • 3,382 Answers
Take it back and ask for your money back or an exchange, they will help you.
Posted on Nov 27, 2014
Why won't my food processer work? The blender works on the same base so what am I doing wrong with the processer? Mode KAPCRD 1KWA
It sounds like the safety lock on the lid. With many processors you can lock the lid 180 degrees from where it is supposed to be. Make sure the lug on the lid is into the slot on the Bowl handle.
Jan 17, 2018 | Blenders
Why won't my food processor work? It is assembled correctly and it is still not working
Make sure you didn't trip your breaker to the power source .
Check to make sure when you put your bottom on and lock it that it is hitting the safety switch hope this helps.
Aug 07, 2015 | Cuisinart Smart Power Duet Blender/Food...
The blade won't 'lock' on my kitchenmaid food processor. It is new.
The blade off the shaft or on it will not prevent the processor from starting. The safety interlocks are on the bowl, lid and pusher so look there for the problem.
Feb 20, 2015 | KitchenAid Kitchen Aid KFP715OB - Food...
Food processor is leaking oil
There is next to no oil in a food processor. Sure the top bush/bearing is lubricated with oil but gravity does not go up no matter where you are from.
Feb 06, 2014 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Food processor won't turn off
Probably going to require a new 3 button switch panel, they are not hard to fit.
Feb 17, 2013 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Cuisinart DFP-14 Series does not start
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor plugged in and turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. For the DFP-14, remember: handle faces front, feed tube faces back, and metal element on back of pusher faces back of processor. Connect the pieces separately - if you try to put the work bowl on with the lid and pusher already attached, it will not always lock properly. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 17, 2008 | Blenders
Attaching top container to bottom tub.
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Nov 13, 2008 | Cuisinart BFP-703 Blender
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Open Questions:
See all Cuisinart Custom Pro 11-Cup Stainless Steel Food Questions
Cuisinart Custom Pro 11-Cup Stainless Steel Food Processor EV-11PC7 OPEN Logo
131 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
