Question about Hunter 44260 5/1/1 Program Digital Thermostat
Hunter themostat 44260 indiglo not working. changed batteries 2 times still not working
Changed batteries 2 times
    Master:
  • 571 Answers
Replace the thermostat.
Posted on Nov 23, 2014
Troubles setting up a thermostat
The work setting would be only used if everyone in the household has he same schedule. If everyone leaves @ 8am, then set the leave @ 8am. If everyone returns @ 5pm, set the return to 5pm. Most programming done by me does not use those 2 settings because most peoples schedules don't correlate. Some thermostats can even be set up to delete those 2 settings, and only use the sleep & wake for night setback.
Feb 11, 2014 | Hunter 44260 5/1/1 Program Digital...
I have an Hunter Indiglo 44250 thermostat. I changed the batteries and now have nothing on the screen at all. I tried resetting it already and nothing is happening. Thanks!
Having a problem with my fan staying on continuously even after my furnace has finished heating. Cool air blows throughout the house all day and night.
Aug 09, 2010 | Hunter Fan Company 5/1/1 Programmable...
My Janittol HPT 18-60 has posts marked Y, G, R, O, W2, E and C. The Hunter thermostat 44260 has fewer post connections G, RC-RH (with Jumper), Y/O, W/B, and Y1. What is the conversion and which wires are...
If your current thermostat is using all of the posts, you most likely have a dual stage heat pump system. A dual-stage heat pump system utilizes electric strip heat as backup heat for use during defrost cycles and to supplement the heat during outdoor temperatures below 30 degrees.
Here is an excerpt from the installation guide of the Hunter 44260 t-stat as well as a link to the guide itself.
"This thermostat is not designed for multi-stage heat
pump systems"
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42711.pdf?n=6278
Feb 25, 2010 | Heating & Cooling
My thermostat displays E What does that mean?
Hi, that is the indication for "Error" and you should first replace the (2) AA batteries in the thermostat, (even if you just replaced them recently) and then using a small paperclip, reset the thermostat, by inserting the unbent end of the paperclip into the reset hole next to the keypad.
Be advised that this will reset the thermostat to the default temperature and time cycle settings, so you'll have to reprogram the unit, once you've reset it. With your unit, you only need to set a weekday setting and one for each of the weekend days.
Here's a copy of the instructions for your use in resetting and reprogramming the thermostat, once you've replaced the batteries.
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/44260.pdf
You can also contact Hunter tech support, should the above info not get your thermostat back in working order by calling them at 1-888-830-1326, from 8 AM to 5 PM Central Time.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
What is the term. y1 used for 0n the hunter thermostat
y is the condensing unit outside trace the wire b is used as a common in most cases but it all depends on what the installer decided to use. Be careful not to burn up your transformer or circuit board.
Aug 11, 2009 | Heating & Cooling
Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Apr 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44260 5/1/1 Program Digital Thermostat Logo
150 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
