Question about Microwave Ovens
I've had two of these microwaves and they both had the same problem-- shooting sparks or it would just stop working altogether. When I sent mine back for a refund the company replied that the problem was something we did but its apparent this product should be recalled!
    Top Expert:
  • Microwave Ovens Master
  • 26,177 Answers
If you clean the wave guide cover and use the correct racks, it will no longer spark.
Posted on Nov 22, 2014
  • Demondra Curry
    Demondra Curry Nov 23, 2014
    I cleaned it and I've never had this kind of problem with any other microwave but I see other customers with the same complaint.
4 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
Posted on Sep 27, 2009
Testimonial: "Thanks for the help! I'll try it and let you know."
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave won't work after lightning storm
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number
here.
You should check the fuse, the magnetron thermostat, and the oven cavity thermostat.
Accessing some components (the oven cavity thermostat for instance) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on May 16, 2010
  • 6771 Answers
SOURCE: GE JES1290SK microwave magnetron is arcing
I don't know about a recall, but if your unit is under warranty parts and labour are included in most cases.
Posted on Sep 03, 2012
Shooting sparks out left side near bracket for shelf
if there are any sparks inside the cabinet it is time to throw the microwave out or send it out for a powder paint $$$$$$
Nov 27, 2013 | Kenmore Microwave Ovens
Microwave sparking
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 29, 2013 | Bosch 500 HMB5050 Microwave Oven
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
Mar 20, 2011 | LG LRM1230W Microwave Oven
My samsung microwave model SMH718 keeps showing an error code -SE- and keeps beeping in 4 beep intervals. How can I correct this?
I had the same problem, I changed the daylight savings time on mine and it worked untill summer, then it happend again. Finally mine quit working altogether. P.S. when this first happend samsung didn't even know what the error coded meant. It is an engineering code, meaning service engineer I believe. If it is beyond the year warranty your hosed, it would cost so much to try and fix your better off buying a new one.
Oct 25, 2010 | Samsung Microwave Ovens
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Dec 11, 2009 | Daewoo KOC-925T Microwave Oven
Microwave is shooting sparks from the bottom it is a Goldstar made in 2003.
Hello, W/D here.
Sparks shooting out of anything is bad news. The good news is that the price of microwaves has fallen quite a bit, and the technology has actually improved, even since 2003. Making even a service call to repair your microwave will likely cost you more than it is worth. Your money will be better spent in placing it towards a new microwave. This is just my opinion, but I have worked on a few of them.
Best regards, --W/D--
Aug 16, 2009 | Goldstar Microwave Ovens
Mircowave blew
inside check transformer and heating element
Feb 27, 2018 | Amana ACO1840A Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
