Question about Canon Np-3030/3050/npg-5 1376a003aa
Canon np3050 showing the code E010 this code is which part problem
  • 24 Answers
Main motor lock, main motor rotation sensor, main board. I'd first look at the motor is your issue. Due to the age of the machine, I'd wish you loads of luck!
Posted on Nov 23, 2014
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
Mar 28, 2012 | Canon Office Equipment & Supplies
I have canon np 6650 it shown E010. i have try to reset, checking the fuse on the dryer paper please help me
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
Aug 11, 2011 | Canon NP 6650II Copier
I use canon imagerunner 330. what happen when it says switch main power off and on. E010 do i have electrical problem or technical problem
The Error code E010 means that there is a drag on the main motor. I would look in the fuser unit & see if the lower fuser roller is damaged or that the cleaning web is wraped around the upper fuser roller. Also try to turn the fuser. You may have a siezed ball bearing. Also, try to remove the drum unit and close the door and see if the code is gone, if so you have a problem with the drum unit, but I would say it is in the fuser unit...... Good Luck
Sep 05, 2010 | Canon imageRUNNER 400S Copier
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
Need service manual for Canon NP3050 Copier
http://www.user-service-manuals.com/canon/np.shtml
-NP3050 English Service Manual NP3050/3030 \Canon\ALL\NP3050_esm.pdf Id-Canon-FY8-13BK-020
Apr 19, 2009 | Office Equipment & Supplies
Canon NP 6030 Error code E010
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
Canon Np-3030/3050/npg-5 1376a003aa Logo
65 people viewed this question
old marine
old marine
