Question about Car Audio & Video
Hi, battery went flat on car and radio code with car is incorrect as 3 attempts failed, only locked out. numbers on side are Cl040161049572C C70000003222 Display now shows PHONE as code I
The above and failed, help needed. thanks
  • 1 more comment
  • DAVID BURNETT
    DAVID BURNETT Nov 22, 2014
    Radio is a Clarion Pu 2294a CD player
  • Colin Stickland
    Colin Stickland Nov 22, 2014
    4456 is what its spitting out on the codey thing but i can only enter the last four numbers 3222 of the numbers you posted so i just dont know ,if it doesnt work then replace the radio ,their cheap enough for a new one with USB and phone input and all that stuff ,me i just listen to the engine
  • DAVID BURNETT
    Hi Thank you, do you know why the display would show the message phone ?
  • 22,326 Answers
Would help if you posted the make of the radio ,i cannot get any coder thingy to work from thses numbers
Posted on Nov 22, 2014
Testimonial: "Hi Colin, thank you for code, radio is now working today ? thanks Dave"
starlet4life
  • 89 Answers
SOURCE: Can't get past 'SAFE' on Phillips radio
Usually you need a dealer to unlock the NEW ones after entering 3 wrong codes but...
http://www.davidsonelectronics.co.uk/code_entry.htm
Posted on Oct 15, 2008
  • 28 Answers
SOURCE: Wait 1 hour message will not cancel.
try 4070 bpo120y1610840
try 0373 BP120Y1677175
Posted on Jan 22, 2009
SOURCE: need security code for car radio
take out the radio by just pulling it toward u and take it to a holden dealer and they will get the code for u for $40
Posted on Jul 12, 2009
  • 4944 Answers
SOURCE: radio pin code input.
The normal method of resetting an ERROR display after a wrong code is to leave the radio SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself.
This may take several hours.
Make sure you have the CORRECT code.
Posted on Nov 25, 2009
aymantn
  • 109 Answers
SOURCE: siemens cdr 2005 vdo code problems
Just see hear :
http://car-radio-unlock.blogspot.com/2009/12/code-calculator-for-renault-radios.html
Posted on Mar 17, 2010
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
Oct 15, 2012 | 1996 Volkswagen Golf
My radio still says code I have removed battery
Hi, most security coded radios will display the word "code" or something similar when requesting code entry after power has been removed for some reason. the usual procedure is to simply enter the code at this point following manufacturer procedure.
If you have had more than 3 incorrect attempts at entering the code, the radio may have gone into codelock which locks any further attempts out for a period of time (up to 1 hour). the only cure for this is to leave the radio powered up so it can timeout at which point it may display the word "code" again.
NOTE disconnecting the supply to the radio while it is in this condition only serves to reset the timer and you have to wait even longer.
Aug 13, 2010 | Philips Car Audio & Video
I am getting an error e code for my stereo after replacing my battery.
There have been too many bad radio code entrys and the radio is now locked out. To clear this you must remove one of the battery cables for about 30 seconds. After reconnecting the battery you enter the code for the radio. If the code is incorrect or entered out of sequence you will get an error message. Too many bad entrys and the radio will lock out. Your local dealer sould be able to help with this for little or no expence. If the code is incorrect they can get it for you easily by accessing the radio serial number through the radio itself, without removing the radio. They can use this information on line with Honda to get you the correct code.
Mar 01, 2010 | 2004 Honda Accord
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
Dec 17, 2009 | 1999 Mercedes-Benz E-Class
Acura car stereo lock codes my stereo needs a code is a Acura 3.0CL now it says err-3 can some one help
err-3 means you have entered incorrect anti-theft radio code more that three times.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 30, 2009 | 1998 Acura CL
Unlock code for volvo cd/radio
To unlock the radio, enter the four-digit
security code found on the removable
label.
If the code is entered incorrectly, you
can try 2 more times. After 3 incorrect
entries, the radio will display “LOCK.”
You must turn the radio off, while leaving
the ignition and battery on, for 1
continuous hour before attempting to
unlock the radio again.
Mar 21, 2009 | Car Audio & Video
1995 honda accord radio lock code
when the car was brand new it had or should have had a sticker on the radio telling u the code. if u do not have the sticker only the dealer can figure it out by researching the part number.
Feb 23, 2009 | 1995 Honda Accord
Oct 14, 2008 | Car Audio & Video
Radio code
i need the radio code for my honda accord
Aug 27, 2008 | 1995 Honda Accord
Lock code for radio cassette
After failing to enter the correct code in 3 successive tries, you must leave the key in the "ignition on" position with the radio on. This will allow you 3 more tries to reset the 5 digit code.
If you enter an erroneous digit, you must complete the 5 digit code, even though it is wrong. You have 2 more attempts to enter the correct code.
Charlie
Jun 25, 2008 | 1994 BMW 3 Series
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
