Question about Roku Streaming Stick
What is error code 011
I followed directions and reached about 88 percent loaded
    Master:
  • Roku Master
  • 426 Answers
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the streaming stick might be too far from your wireless router. Try to move the router closer to the Streaming Stick if possible. The best way to watch streaming video is with a wired Ethernet connection with a Roku 3 or other wired device.
Posted on Jan 01, 2015
How do I get past error code 011
An error code 011 means that the Roku player have lost connection with the server.Try again later to reconnect.Additional help link: am seeing Code 011 error during setup What should do
Jan 08, 2015 | Roku Streaming Stick
Just installed new roku going through set up menu goes to get newest update and kept getting error code 011
That error code is usually associated with the firewall in the wireless router. If you turn off the router firewall then the Roku should be able to access the Internet to perform the update.
Jan 01, 2015 | Roku Televison & Video
Roku error code 011
Roku Error Code 001 is usually when the TV is not able to reach the Roku.com/link activation server. If Roku Error Code 001 occurred on your screen then you need to follow these simple steps:
· First of all, you have to press home button 5 times.
· Then press fast forward (FF)button 3 times from Roku remote.
· Also press rewind button 2 times then "OK" button.
· Now your Software is updated.
· After updating software, you need to connect to a network connection.
· If these steps don't help you then you need to reset your device and retry it again.
How to Solve Different types of Roku Error Codes Roku Com Link
Dec 10, 2012 | Roku 2 XS
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
I cannot make international calls from my IPAD. I am adding 011 after +1...then the number
If you are calling from the US then you would type 011 followed by the country code, for example, for the UK you would dial 011 44 followed by the area code (dropping the leading zero) therefore, for london you would dial 01144208. If you go to:
http://www.countrycallingcodes.com/
this site will provide you with further instructions.
Mar 09, 2011 | Yahoo Mail
CHECK ENGINE LIGHT ON CODE P0170
DTC P0170 applies to fuel trim malfunction on all 2.4L vehicles, 3.0L Federal vehicles and right bank (bank 1) on 3.0L California vehicles.
DTC P0173 applies to fuel trim malfunction on left bank (bank 2) on 3.0L California vehicles.
DTC Set Criteria (2.4L)
Engine is in closed loop control. Intake air temperature is more than 14°F (-10°C). Barometric pressure is more than 11 psi (76 kPa). Volume Airflow (VAF) sensor output frequency is 88 Hz or more. Code will set if long-range fuel correction is less than -12.5 percent, or more than +12.5 percent, for 5 seconds and short-range fuel correction is less than -10 percent, or more than +10 percent, for 5 seconds.
Engine is in closed loop control. Intake air temperature is more than 14°F (-10°C). Barometric pressure is more than 11 psi (76 kPa). VAF sensor output frequency is less than 88 Hz. Code will set if long-range fuel correction is less than -12.5 percent, or more than +12.5 percent, for 5 seconds. On 2.4L code will also set if short-range fuel correction is less than -15 percent, or more than +15 percent, for 5 seconds. On 3.0L Federal code will also set if short-range fuel correction is less than -13.5 percent, or more than +13.5 percent, for 5 seconds.
Have the O2 Sensor changed on the Right Bank, ( passenger side of the Engine, or where the # 1 cylinder is.)
Good luck and hope this helps
May 02, 2009 | 1997 Mitsubishi Mirage
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Roku Streaming Stick Logo
222 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
