Red light flickers occasionally.. Screen doesn't switch on at all??
  • 44 Answers
Power supply - to replace faulty electrolytic capacitors
swollen or drains
-check the inverter
Posted on Nov 23, 2014
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
  • chris wright Nov 23, 2014
    It's ok...the plug had corroded.. Simply changed the plug..and solved it...
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
Bose L1 Speaker Distorting
See this article on the inputs on the Bose L1®.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Set the trim levels so that lights are solid green with occasional flickers of red.
Mar 15, 2012 | Bose L1 Speaker
The lights flicker on the dash and headlights flicker while driving
You have a loose connection in your wiring somewhere. Unfortunately, this can be time consuming to find. Start with the fuses to make sure they are all good and making good connections. If this doesn't solve your problem. Start tracing your wiring, checking all connectors to make sure that they are connected properly and not broken. If this doesn't solve your problem, you may have a wire that has broken inside of the insulation and occasionally makes contact so stuff works. This is a b*tch to track down. Start at the battery with a test light and at every connection, take the connection apart, stick the test light in the connector and wiggle the wire to make sure it has juice continually going through it. My suggestion is that if it comes to this, have someone else do it.
Aug 24, 2011 | 2001 Dodge Stratus
RCA drc286 screen flicker
it sounds like the vertical hold on your tv set needs adjusting also with your tv and dvd are there a set of three plugs usually red,white and yellow in colour ?? if so connect these with a cable as this by passes the tv tuner hope this helps regards JIm
Mar 12, 2009 | RCA DRC-285 DVD Player
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Panasonic BL-C20
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Aug 16, 2008 | Panasonic BL-C30A Network Camera
Red Lines
Can you bring up the menu and see the menu over the red lines? Does the menu have red lines over it? I suspect the light engine is bad. Might want someone with experience to tackle that problem.
Jul 04, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
