Question about Beko DSV64W White Vented Tumble Dryer 6 kg, 9 Cycles
Change door from left to right opening
Want to change to from one side to the other
    Master:
  • 371 Answers
Unfortunately, if you double-check me here at the SPECIFICATIONS page of this dryers website link, it does not appear that this door IS interchangeable. I hope for your sake to be wrong but cannot find any information to state otherwise:
See here: http://www.beko.co.uk/Item/DSV64
change door from left to right opening - 16036f05-0da7-45f1-b2f7-4166c3485c22.jpg
Posted on Nov 25, 2014
  • Lesley Cameron
    Lesley Cameron Nov 25, 2014
    Forgive me – I stand corrected! The instructions are on page 23 here: http://laundry.manualsonline.com/manuals...
  • Lesley Cameron
    (instrux added above to previous comment above)
Blizzard lb 1ss upright freezer change door opening
Under the bottom hinge, unbolt it, remove plastic plugs on other side of door, transfer hinges over and door handle, refit the lower one in new position, put plastic plugs in old holes
Mar 12, 2013 | Freezers
Switching door sides
some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
Jul 24, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
Feb 19, 2010 | Hotpoint RLA30 Compact Refrigerator
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Change sides for hinges
doors are reversible but a little work.once you start taking hinges off you will see inserts that are covered with a plastic grommet.pull those out and put grommets back on other side.you should see it is very easy but time consuming.
Mar 06, 2009 | Whirlpool ER6AHKXPQ Top Freezer...
Can you switch the side the doors open and close.
sorry but the washer can not be changed. its strike has a lock and can not be reversed. the dryer can be changed, but the best thing to do is move the units and get some longer hoses for the washer.
hopefully you can switch the position of the units, but if not then you will be doing the laundry dance every time you do wash.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Beko DSV64W White Vented Tumble Dryer 6 kg, 9 Cycles Logo
102 people viewed this question
Top Beko Dryers Experts
shaun taylor
Are you a Beko Dryer Expert? Answer questions, earn points and help others
