Question about Dell Dimension 2200 (A-D0601) PC Desktop
I bought secondhand PC with o/s still on it, however the mouse pointer is still on the screen, got a new mouse but its not working, puzzled!
There's not much one can do, checked USB,fine, tried it in all sockets, still pointer stuck in middle of screen, would the problem be caused by the old O/S which is XP? Because of this mouse problem, I can't load new O/S which I have, however there are some good program that I'd like to retain!
    Scholar:
  • 93 Answers
The computer should recognize the mouse and install it automatically if it is not you might have to go into add new devices. Use the tab and arrow keys to navigate if it is connected to the internet you might be able to down load and install a driver .if the mouse came with a driver disk even better.to navigate click the tab key and watch what gets highlighted when the start button is highlighted click enter then usr the up down arrow keys to go to
control panel then use tab to navigate to add new device manager you should be able to get windows to search for the device. If this doesnt work you may have to shut the computer down and go into bios and check that usb is enabled you can use the key board to do this also .Depending on what type of computer you might have to press the delete key on start up or somtimes the f2 or f 12 key some times it tells you on the bottom of the screen when it it booting up. which key to press. I hope this helps. If you aren't sure of these steps then let me know if you need more help.
Posted on Nov 24, 2014
EcoPcKing
  • 76 Answers
SOURCE: DELL PC logitech cordless mouse and keypad.
tell me more about this screen image turning on it's side..do you mean that instead of being right side, up, it's on the horizontal?
Posted on Nov 21, 2008
  • 916 Answers
SOURCE: my mouse pointer is stuck on my log in screen
If it is a usb mouse you could try using a usb to ps/2 converter some machines will not support usb mice and keyboards.
Posted on Dec 18, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: Dell C521 Will boot to User login But cannot use mouse or keyboar
did you try starting the computer with both mouse and key board allready pluged in so it can recanize that there pluged in,no any mouse and key board will work also did you switch the 2 to make sure you did'nt have them pluged in the others spot?
Posted on Mar 10, 2009
  • 468 Answers
SOURCE: the mouse is stuck and i've restarted the pc and
It is very easy to damage mouse port so maybe is best idea to use USB mouse
Posted on Feb 28, 2010
mouse_kil
  • 93 Answers
SOURCE: Keyboard & Mouse not inputting..Dell
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Posted on Apr 09, 2011
The guide button has stopped working. Bought a new touchpad but guide button not working on it either.
Good morning David.
It sounds very much like a setting issue. I'll give you an example for Windows 7. If you're running another version of Windows, MacOS, Linux, or what have you, you'll likely have to make small adjustments.
  1. Go to Control Panel, then to Mouse.
  2. The Mouse screen will have tabs like [Buttons], [Pointers], [Wheel], and, in my case [Dell Touchpad]
  3. In this case, the Touchpad tab has a 'click to adjust' that brings up another panel that adjusts both the touchpad and the 'PointStick' (in this case, on/off for the pointstick, and adjustment for pointer speed and clicking speed.
Working from your OS specifics, and possibly your PC/Laptop model, a specific search on 'How do I turn on guide button on Model in OS Name?' will give you variants of what I wrote above.
Good Luck, and Happy Holidays!
D
Dec 09, 2015 | Computers & Internet
The mouse that came with it was not used until yesterday and it sometimes lights up but even when it does, it does not work the pointer.
If the mouse pointer works with a different mouse, then the problem is with the mouse that you are using now. You will need to get a new one if that's the case.
Nov 27, 2012 | Gateway DX4200-09 PC Desktop
The receiver for my wireless mouse just suddenly started freezing my Vista machine from booting. Just a blank screen with cursor flashing. But if I remove it before booting, it boots fast, then plug i
Try looking for a "patch" on the manufacturers website. You did not supply the Make, model of your machine.Are your windows vista updates current?
Nov 18, 2012 | Computers & Internet
Drifting mouse pointer
Go to Control Panel - Mouse - Pointer Options - and uncheck 'Enhance pointer precision'.
Feb 28, 2010 | Dell Precision M60 Notebook
Mouse Pointer Doesn't Move
return that , it isn't your pc
Jul 04, 2009 | Computers & Internet
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Fixing optical mouse problem
try a diff mouse. try a diff usb port
Jul 31, 2017 | HP OPTICAL SCROLL MOUSE (8131)
Dell Dimension 2200 (A-D0601) PC Desktop Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
