Question about Broan-NuTone Kitchen Ranges
Light switch broken off fell in hole....
Nothing can get to the switch in hole....
  • 3,382 Answers
You need to disassemble it to repair it, if you are not comfortable check into either a service person or replacing it.
Posted on Nov 27, 2014
Location of lean angle cut off switch
Depending on the make/model of your bike, there might be a "kickstand" switch (which prevents you riding off with your kickstand down) sometimes this can be faulty (or broken from a fall over) and prevent the bike from starting. I would check (bypass the switch) usually located near where the kickstand attaches to the frame, to see if the bike starts with the switch bypassed. If it does, replace (or remove) the switch. Depending on which side the bike fell, you might have damaged the kill switch (generally located on the right bar/clip-on). Basically carefully inspect the side of the bike that it fell on, look for any obvious signs of damage and then meticulously inspect that area for loose/broken wires/connectors. Do all the lights, instrument panel light up when the key is turned on? Check the battery connections. There are numerous possibilities, but use standard troubleshooting methodologies and you should be able to find or narrow down the problem. For future reference I think you were probably referring to the kickstand switch as opposed to to a "lean angle cut off" switch, which would be very dangerous to have on a motorcycle. Anyway, if you want/need more help. Post some more details such as; make/model/year, side it fell on, do the electrics (lights, turn signals, brake light, speedometer, tach etc.) work (or which don't & under what circumstances), does the started motor turn etc. etc. etc. Good luck.
Aug 16, 2014 | Motorcycles
Hazard switch fell through dash board
youll have to take the pannel off the dash and retreve the switch.make sure it click or snaps back in its origional hole or you may need a new one..
Apr 08, 2014 | 2008 Chevrolet Cobalt
Door switch fell in the hole, how do I get it out?
yes remove plastic cover on the inside of the car,on pillar you might get it
Jul 16, 2013 | Honda Cars & Trucks
Brake light stays on
CHECK THE BRAKE LIGHT SWITCH.IT COULD BE LOOSEN FELL OUT OF PLACE OR THE BRAKE SWITCH IS BROKEN.
Jun 11, 2010 | 1994 Nissan Altima
Left rear spring fell out of car. What could
the shock may have broke or came loose or the spring broke and fell out,take a look at the springseats at the top and bottom to make sure they are not rusted or broken then look at the shock if nothing is broken or missing bolts then the spring just broke and fell out,
May 10, 2010 | 2001 Volkswagen Beetle
Tv fell on floor and now does not switch on
Take the aparts.Check all PCB boards.Might have PCB boards broken.Might even have LCD screen pannel broken,not worth repairing if LCD screen picture pannel is broken.
Mar 17, 2010 | Televison & Video
I dropped the razor and the 3 heads fell off, nothing is broken, but I can't figure out how to put it back together Help!
all you have to do is put them back in there place you should have two legs that spring out from the blades align them with the 2 holes on the shaver and push them in
Oct 21, 2009 | Philips Philishave HQ8150 Electric Shaver
Brake lights remain on when engine off and key removed. Fix how?
Hi I'm litoshop your problem is not that hard to fix under the dash on your brake pedal you have a switch, that's your brake light switch it may need adjustment look under the dash some switch will adjust by screwing it in if yours don't have adjustment then you need to replace the switch good luck. if this information has been helpful please let us know thank you
Jul 29, 2009 | 1991 Nissan Pickup
Rear brake lights always on
you have a badbrake light switch
Feb 10, 2009 | 1992 Daihatsu Charade
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Ranges Logo
115 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
