Question about Dell V525w Wireless All In One Inkjet Printer
Why does my dell printer yellow in the area where red should be?
Yellow color is printing where red should be.
  • Dell Master
  • 5,631 Answers
Probably not getting red ink. You should chek the level of your red ink. Also the cartridge mighbe be obstucted. Install a new red ink cartrirge
Posted on Nov 22, 2014
2 Suggested Answers
  • 59 Answers
SOURCE: Dell 1250C color laser printer using A5 200gsm light card. Problem patches of color rub off and dirty residue left on non-print areas
Usually when you get some color rub off what you are trying to print, it means that the ink waste pad are getting to full.
Every time you initialize the printer, test it, replace a cartridge, it needs to test by trying to get the ink out. When it is doing so without paper, the ink goes into an absorbant fabric usually called waste ink pads.
In your case you can ask Dell support where these are located and take a look at them. If you see that they are overflooded with ink there is your issue with the plinting residue.
Most of the time these pads are not officially replaceable, beacause it is better economically speaking to change the printer rather that going to the hassle of changing these.
But if you have time and are not affraid of taking appart your printer, you can either remove them and chang them, or try to clean and dry them then put them back.
It is difficult but sometimes it is the only way, because in cases were it is not supported bu the manufacturer you will not find any proffessional computer shop to do that job, and even if you find one it won't be for less than the price of a new equivalent printer.
Hope this helps.
Posted on Nov 08, 2013
How do I get my Dell 2150cdn printer to print red?
Call Dell. Only they can fix it. They attach to a laptop with a diagnostics program. We had the three of the same machine.
Nov 27, 2017 | Dell 2150cdn Laser Printer
Dell 3100cn prints the wrong colors
Go to Control panel
Click on: Hardware and Sound
Click on: Devices and Printer
Click on your printer
Click on Adjust printing preferences
Then go to the Maintenance Tab at the top (should be last tab)
Then click Print a test page
You can also Align Ink cartridges from here and clean the Ink Cartridges
If that does not work then update the drivers:
Go to Start
Type in box Device Manager
Click on Device Manager in list
Wait till list populates.
Click on Imaging devices
Right click on the printer
Update the drivers by searching online
Apr 03, 2013 | Dell Laser Printer 3100cn PCL6
Just wondering: my printer's yellow and black toner are both empty and need replacing. Would this cause the printer to calibrate for minutes at a time? After calibrating, I tried printing a document with...
If your going to print in color may it be just red or blue. You really need all of the cartridges for it to work. Because for the printer to come up with those colors. It would need all three colors Cyan, Magenta and Yellow to come up with the any color, in your problem, Blue and Red.
Feb 04, 2011 | Dell 3100cn Laser Printer
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
Yellow toner usage is high , ventilator at back panel is yellow. Cannot print pure red colors
I would guess the yellow toner cartridge is leaking. Clean out the printer, including the fan and air path to the back panel vent, and inspect the mechanics of the yellow cartridge section. If no abnormalities are seen there, try a different yellow cartridge. Stray or excess yellow toner might mess up all of your colors - do you see green blotches in blue areas?
If you had normal toner usage, I'd suspect a problem with the corona wire for yellow that lets the toner blow away from the paper instead of adhering. That would leave your reds with a magenta hue and paint the fan yellow.
You could even have both problems if toner powder has contaminated the high voltage contacts.
Dec 09, 2009 | Konica Minolta bizhub C351 All-In-One...
Printer prints colours in different colours
Either you are out of red ink or the print head is getting plugged. Most printers substitute the nearest available color when a color runs out or the head is plugged. As some shades of red are made with yellow mixed, it therefore prints only in yellow if red is unavailable.
Aug 30, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Light or Faded Areas in Solid Color Prints
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
Nov 27, 2008 | Dell 3010cn Laser Printer
Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
Feb 18, 2007 | Dell 962 Photo All-In-One InkJet Printer
Dell V525w Wireless All In One Inkjet Printer Logo
83 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
