Question about GE PTWN6050MWT Washer
Why won't it start when I push the start button ?
Unplugged and plugged in power cord
  • GE Master
  • 744 Answers
Hello Carl;
My name is Peter. I am a retired field service appliance technician.
There are several possibilities so lets start with the most probable:
First, you will need to have a multi-meter. Set the meter on Ohms the lowest setting (X1). Touch the two meter leads together. Observe the meter reading. When you touch the contact ends with the meter leads you should see a reading of '0'. if the component is good. Any other reading the component is bad.
A multi-meter is relatively inexpensive. You can purchase one for about $20.00 - $30.00. This is a wise investment. You can use the meter to determine bad components on all of your appliances and more.
Ok, you do not have a multi-meter. Well then we are going to jump the component. For this we will need about a 12 or 14 gage wire approximately 6" long. Strip the wire about 2 inches back on each end.
1.) Washer Fuse: Item 20 on diagram. Part Number WH49X10055
why won't it start when I push the start button ? - 25293548-r2x1rhghuhaj0fk23keia5m0-3-0.png
2.) Lid switch: Item #388 Part number WH12X10334why won't it start when I push the start button ? - 25293548-r2x1rhghuhaj0fk23keia5m0-3-8.jpguploads/images/25293548-r2x1rhghuhaj0fk23keia5m0-3-8.jpg" alt="25293548-r2x1rhghuhaj0fk23keia5m0-3-8.jpg" class="h_mi" />
3why won't it start when I push the start button ? - 25293548-r2x1rhghuhaj0fk23keia5m0-3-15.pngH12X10412
Posted on Nov 23, 2014
My friend has a WD-65731 Mitsubishi; a week ago the image wouldn't come , so he unplugged the power cord, plugged it back and the image came. But, he wasn't able to turn it off from the remote any longer,...
try this wait until the blinking stops and then press the button. if still not working replace the lamp and lamp ballast. before changing lamp make sure you clean the dust out using a compressed air.also clean the small fan over the lamp ballast.
Sep 10, 2010 | Televison & Video
InFocus LP 250 Multimedia Projector was working fine until i unplugged it and when I went to plug it back in, I used my computers power cord instead of the projector but the plug is almost identical. I...
The plugs on this model projector is very delicate, over time the solder around the plug will begin to crack. Until eventually the connection is lost. Another possibility is that the power supply has gone bad. Using another cord would not cause this. I can fix the projector if you'd like. My ebay screenname is gtitubro.
May 11, 2010 | InFocus LP 250 Multimedia Projector
The power cord is plugged in. The power icon says
Go to the Dell website and chat with someone and they will give you a new one for free.
Feb 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
My toshiba laptop won't turn on!
Place the battery back in and the power cord. Follow the power cord all the way to the plug and verify nothing was unplugged by accident. (the box on the plug sometimes disconnects without the user knowing it) This could have caused your lack of power. Hope this helps.
May 09, 2009 | Computers & Internet
No power
Check your power cord very carefully....especially the plug ins (square box)....could be the power supply itself. Regarding fuses; You can't see it inside the computer it is an electronic component. Got to go to store
Feb 27, 2009 | KDS 17S 17" Monitor
Unplugged Hood power cord
YES THE POWER BEING SHUT OFF THEN ON WITHOUT THE LIGHT SWITCH BEING INTHE OFF POSITION BLEW YOUR LIGHT BULB. IT COULDN'T BE ANYTHING ELSE UNLESS YOUR CORD HAS A FUSE. CORDS WITHA FUSE ARE FAT AND ODDLEY SHAPED AT THE END U PLUG INTO THE LIGHT.
Sep 10, 2008 | Sunlight Supply 400 Watt Hps Sunsystem I...
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
GE PTWN6050MWT Washer Logo
130 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
