Question about Halonet 95-99 NISSAN MAXIMA / 96-99 INFINITI I30 POWER FRONT WINDOW REGULATOR W/ CABLE
How do i pull out the ingition swits
Every thing
Back passenger power window stopped working
I can help with a little testing. On the hinge side of rear passenger door, should be a wiring harness. Probably has a protective rubber boot covering, pull the covering back far enough to get at wire colors in the diagram. One wire is voltage the other is ground depending if the window is going up or down. Use a test lite to check. Key on, I would think.Your front passenger window works ok? If the wires check out good for voltage and ground, could be something wrong with window motor?
Oct 22, 2017 | Cars & Trucks
Happy xmas. I have a hds 745. Use it every week, yesterday i turned it onand it tripped the rcd o the consumer unit i my garage. Ichecked the mains cable and that is ok. Changed the plug too as it looked...
It could be one of two things, first have you bleed the pressure off the unit then tried to restart it. or it may be the pump is locked up and will not turn.
Dec 22, 2014 | Garden
My gauge fuse blows when start engine
disconnect the gauge,put new fuse in and see if it blows again.
the will be a chort in the fan off the gauge or on/off swits.
if he blows again disconnect the swits.
May 04, 2014 | Chevrolet Blazer Cars & Trucks
Honda keyfob reset
Ingition switch on -> press lock
Ingition switch off -> on -> press lock
As fast as u can on the fifth cycle the car will lock
program is complete
Feb 15, 2014 | Alarm Remote Casecover Accord Odyssey 02...
Tinto S534 mobility scooter
you need to by a lefthandeddrive .cause when you chould swits the,
manet ,you have to puch it to get power insteadt off pulling to get power.not very handy.you can get the left grip off by using pressed air,
or whit some soap..
Feb 14, 2014 | 1991-1994 4.0L 242ci Manual Transmission...
Need to replace ingition switch?
If this is for a car you more than likely have to pull the steering wheel. This requires a steering wheel puller and a little know how. It is not a fun job.
Dec 07, 2011 | Computers & Internet
Swit problem don't listen to radio
Some options are available in the phone........
Apr 01, 2010 | Nokia 6600
Need diagram of 1994 Accord sedan, ingition. Need
go to advance auto.com. they pull up what you need and show you the part
Nov 18, 2009 | 1994 Honda Accord
Halonet 95-99 NISSAN MAXIMA / 96-99 INFINITI I30 POWER FRONT WINDOW REGULATOR W/ CABLE Logo
75 people viewed this question
Top Halonet Scuba Diving & Snorkeling Experts
Tom Chichester
Bill Boyd
micky dee
Are you a Halonet Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
