Question about Vehicle Parts & Accessories
90 chevy G20 5.0. Little hard to start. Idles fair, but when driving it hesitates and wont get past 20 mph.
I've replaced plugs, wires, cap, rotor, oxygen sensor, vaccum lines, EGR valve, IAC sensor, throttle position sensor, and map sensor. Vaccum tester shows normal so no leaks there. I put timing light on it and shows good timing. Sometimes the check engine light comes on for a few minutes then goes off. Code 44 for oxygen sensor.
  • 9,639 Answers
You may have some bad connections in the sensor string causing the computer to go into the limp in mode.
Posted on Jan 15, 2015
    Habit-Forming:
    Scholar:
  • 152 Answers
The vehicle is a 1990. I think...After 25 years you might want to replace the O2 sensor. If it can't get past 20-- make sure your brakes aren't locking up. just one brake locking up will cause your engine and transmission to work harder. over-heated brake rotors can swell and cause your car to feel draggy since they heat up the caliper and the piston inside and causing the caliper parts to remain in the closed position creating drag on the vehicle. We can also think about the speed sensor giving the wrong info to your transmission caused by drag thus keeping your transmission from shifting when it should. This can be felt when driving when she begins to drag for several seconds and then jolts as the vehicle builds momentum. This is an indication that your tranny is over-working These are just suggestions.
Posted on Dec 07, 2015
  • 3 Answers
Easy....buy a "Lucas Fuel injector cleaner/lubricant" get large bottle. better deal. Use on the next 2 fillups then every three months. Works wonders and saves you lots of money....
Posted on Nov 22, 2014
94 four chevy starts idles a little then dies sounds like air pushin thru throttle body when you push gas
90% of idle problems, hard start problems, erratic idling, surges, hesitation etc is caused by a dirty throttle body. Remove it, clean it and the intake manifold, replace and it should solve your problem.
Aug 12, 2014 | Chevrolet 1994 Chevrolet 1500 Pickup Radio
2002 chevy express 3500, 5.7 engine, has no power. Error code says random misfire. New cap, rotor, plugs, and wires. New fuel pump. Fuel pressure ranges between 54 - 60 PSIG while driving (and cutting...
The back fire could be from the cam sensor going bad. Do a compression test to be sure it's not a valve. The ignition computer can give you a problem too. Read the error codes to see where it steers you to look.
Jul 16, 2014 | Cars & Trucks
94 Acura Integra wont Start
jump timing loosen distributor and plus or minus turn and retighten
Mar 09, 2013 | 1994 Acura Integra
1996 Z71 5.0L truck starts and runs for awhile then stalls and wont start
How about replacing the coil - might have a thermal issue and shut down when it gets hot.
Aug 18, 2017 | 1996 Chevrolet K1500
Hesitation at speed at 35 mph to 80
sounds like an injector problem, That will cause multiple misfire codes
Mar 15, 2010 | Jeep Grand Cherokee Cars & Trucks
Rough idle
Check or replace the EGR
May 27, 2009 | 1995 Chevrolet K1500
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
