Question about Electrolux White Gas Slide In Stove Range Ew30gs65gw
My stove have code f 23 What this mean? - Electrolux White Gas Slide In Stove Range Ew30gs65gw
  • Official Brand Answer
  • 4,342 Answers
Thanks for your inquiry, Adrian Gonzalez!
From the information you have provided your Electrolux range is displaying an error code of "F23". "F23" stands for communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) I would attempt to perform a reset on your range and you could do that by disconnecting the power from the range for ten minutes. If you continue to experience a problem with the error code it could be an issue with the EOC or VSC (Variable Speed Control) board. Hope this helps. -Matt
Posted on Nov 25, 2014
2005 fxsti diagnostic codes ? I have (from flashing engine light) 23, 32 & 33. can anyone tell me what they mean before I declare war on google ?
Each code has multiple diagnosis.
You'll need to figure which it is.
The codes mean the following (each code has more than one diagnosis)
23 = Front injector open/low
23 = Front injector high
32 = Rear injector open/low
32 = Rear injector high
32 = Alarm output high
33 = System relay contacts open
33 = System relay coil high/shorted
33 = System relay coil open/low
33 = System relay contacts closed
Jun 24, 2014 | 2005 Harley Davidson FXSTI Softail...
Trouble codes 122355
I assume you mean 12 , 23 , & 55 right? If so the 12 means no ignition reference or battery has been disconnected.. (if vehicle not running during test this is OK) 23 mean there is a problem in the IAT circuit (Intake Air Temperature sensor). Could be faulty sensor or poor connection. 55 means end of code string.
Jul 11, 2013 | 1995 Jeep Grand Cherokee
I get a 1 then a 4 then a 23 then it goes to 55 what do these three codes mean the 23 in book says air intake sensor voltage it's on a 1999 3.3 caravan but can't find these three codes what do
Preaty problem you got there but how did u got those codes if it is a 99 you should get a generic obd II code that start with the letter P but try from the basic inspect your plugs and wires and if are those are okay you could have a bad cranck possition sensor but I will suggest you to get a OBD II scaner to see if you can get a generic code
Nov 01, 2012 | Dodge Cars & Trucks
I Bought Prestige induction stove I am getting E5 error can any body help what it means
E5 or E0 means that the stove is getting overheated. You have to reduce the temperature for it to stop. It goes on with few beeps and then stops.
Sep 10, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
I have a brown brand gas stove and the oven is not coming on stove has no electical cords
hello. i can help. here is the manual for your stove. http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
look on page 17 as it tells you how to light the pilot light.
Jun 05, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
Code C:31:23
Already replied.
Error C:31:23 problem means that System Control is not getting Supply Reel pulse. This can be electronic or mechanical problem in camcorder.
Qualified camera tech will fix it properly.
Feb 22, 2009 | Sony Handycam CCD-TRV318 Camcorder
Diagnostic code 23
Loss of horizontal deflection is what code 23 means in that model.
Mar 23, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Brown Cook Top (24 Inch - TTL03-3 Model)
All gas appliance should be diagnosed by a professional.
Aug 12, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Electrolux White Gas Slide In Stove Range Ew30gs65gw Logo
208 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
