Question about Garden
Will not engage reverse. all forward gears are fine
Adjusted shift lever. Checked linkage and keyways at rear axles.
  • 637 Answers
Remove A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
Posted on Nov 22, 2014
Testimonial: "Big Thumbs UP!!!!!!!!!!!!! Thanks"
  • 2 more comments
  • Lou Meola
    Lou Meola Nov 22, 2014
    I don't believe you answered my question. All it said was remove and then you asked for thumbs up. I would gladly give a thumbs up if an answer was posted.
  • FastHarley
    FastHarley Nov 23, 2014
    SorryI didn't realize the answer was not on there when I pressed post answer. You want to remove the linkage and try to move the transmission bar by hand. If you were able to move it by hand this is definitely not your transmission not engaging into reverse but more so its something in your language. This should be able to help you once again Sorry for not posting this earlier
  • FastHarley
    something in your linkage....autocorrect
  • Lou Meola
    Lou Meola Nov 25, 2014
    That is exactly what it was. The main linkage bolt was loose.It took me awhile to figure it out. Thank you for your help
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
1996 Jeep Grand Cherokee. Transmission problems. when the gear selector is in reverse, it doesn't engage in reverse. When you go to neutral, it drives forward but doesn't shift through the...
Put the vehicle in Park, disconnect the shifter from the shift lever on the trans, adjust the linkage or cable so the connection is clearly a slip in/on connection and tighten things back up. Hopefully this will solve your non-reverse. As for all the gunk and metal shavings, friend, you better have another tranny standing by in your garage when this one stops working completely.
Jun 09, 2017 | Jeep Grand Cherokee Cars & Trucks
1990 Porsche 911 Carerra 2 Targa (964)...car was shifing fine...now is stuck in second gear. Clutch will engage...but no other gear is selectable. ...no strange noises...just will not...
YEP SHIFT LINKAGE LOOSE OR WORN NEED ADJUSTMENT.ADJUST THE SHIFT LINKAGE BY POSITION THE SHIFT LEVER IN NEUTRAL .REMOVE THE REAR TUNNEL COVER IN FRONT OF THE REAR SEAT.PULL THE RUBBER DUST COVER FORWARD ON THE SHIFT ROD.LOOSEN THE CLAMP BOLT ON THE SHIFT ROD.MOVE THE TRANSMISSION SELECTOR SHAFT ALL THE ITS LEFT STOP,KEEPING IT IN NEUTRAL.WITH THE TRANSMISSION STILL IN NEUTRAL . MOVE THE GEARSHIFT ROD TO THE RIGHT TO ITS STOP.TIGHTEN THE CLAMP BOLT TO 18 FT LBS.TEST THE SHIFT LEVER PLAY SHOULD BE THE SAME IN ALL GEARS IN ALL DIRECTIONS.
Apr 18, 2011 | 1990 Porsche 911 Carrera
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
I have a 1966 Falcon that has a C4 transmission issue no reverse
Readjust the band, I have ran into this same problem with another C-4.Found the reverse spool valve was sticking in the valve body. Hopes this helps.
Dec 29, 2009 | 1966 Ford Mustang
Car goes into reverce but does not engage completely works fine in forward, when in reverce it seems lik it wants to ingage but does not. it makes a chattering sound and feeling. what electric part puts...
Hello. As you know, the transmission is one of the more sophisticated components in any auto. It takes the most transmission pressure to engage reverse, third, and fourth gear in an auto tranny. In an auto tranny, the shifter is connected to a linkage that manually shifts between the different gears in the transmission. When you shift into reverse, all transmission pressure is concentrated to engage reverse. When you shift to drive the transmission will operate normally, building pressure until it can shift into the next gear. With third, second, or first gear selected it will lock out all higher gears (Unless the TCU detects overrevving of the engine, in which case it will override gear selection and upshift to avoid engine damage). All the TCU does in a modern auto tranny is control shift points. Years and years ago, shifting was controlled by a spring attached to the gas pedal. When the gas pedal was depressed, the spring would expand. As tranny pressure grew, the spring would become compressed until it was fully compressed, engaging the next gear. The harder you stepped on the gas, the longer you went until the tranny shifted. In modern transmissions the TCU dictates shift points, and not much else. The TCU will also control when the torque converter will lock, but that's where it's duties end. The problem with engaging reverse is either a linkage issue, or a problem with the pump not building enough pressure to fully engage reverse.
Try putting the shifter in reverse, holding the brakes firmly, and giving the car gas. If the car reaches a higher RPM and suddenly slams into reverse it is the pump. The pump will only build enough pressure to engage reverse with higher RPM's. If the pump is severly damaged it won't engage at all, but if this is the case it probably won't engage third or fourth gear either at that point. If the problem is with the linkage, reverse just won't engage whatsoever, despite RPM's. I'd say start with the shift linkage. If it's bent or misadjusted it could cause reverse to not be fully engaged. The TCU doesn't control reverse at all, since there are no shift points and no need for the torque converter to lock.
Nov 20, 2009 | 2007 Saturn Aura XR Sedan
2001 Hyundai - reverse gear is inoperative. The
If I understand you correctly, you have ALL forward gears working, but reverse doesn't?... then the problem is in the transmission itself or the linkage on the trans linkage into reverse.
Oct 18, 2009 | Hyundai Accent Cars & Trucks
MTD mower won't engage traction belts
Check to see if rear axle is broke. Jack up the rear of the tractor, put it in gear and spin one of the rear wheels, the one on the other side should spin the opposite way. hope this helps
Jul 13, 2009 | Garden
Transmission wont shift into park
need to adjust the shift linkage
Sep 12, 2008 | 2001 Dodge Intrepid
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
