Question about Astatic Radio Communications
How to wire an astatic 877hl to a kenwood ts 930s
Download the trios manual and connections chart then connect the black and screen to the ground of the plugin socket using a bridge wire ie connect black and screen on the mic then connect them to a small bridge wire then to the ground pin and also the moto plugs metals then usualy white or yellow is audio and orange or brown it TX switching
you can use a multimeter and connect its negative to the ground and set the meter to beep test or low ohms then as i say orange or brown press the TX pedel a low ohms or beep indicates the TX switching the rest is carefull wireup just be warned most ham radios will supply 12v or 9v to the mic socket up and down etc if you have these controls are data so will just read like 10k when pressed relative to ground so you need to set the meter to 20k range etc to get these controls
good luck and post how you got on
Posted on Nov 23, 2014
2 Suggested Answers
SOURCE: emperor ts 5010 stock mic want to hook up d104
http://www.citizensband.radiouk.com/reference/mics/index.php
her ya go regards roger
Posted on Jul 30, 2009
How to install a voice synthesizer into a Kenwood ts 570
This should be of some help to you...
http://www.manualslib.com/manual/86121/Kenwood-Ts-570d-Ts-570s.html?page=64
Mar 02, 2015 | Kenwood Radio Communications
Why does my Kenwood TS 790 E when pressing call button causes C2 fault on display?
http://www.iw2nmx.it/Kenwood%20-%20Trio/TS-790%20Instruction%20and%20Service%20Manuals%20plus%20mods/TS-790%20Instruction%20Manual.pdf
Jul 14, 2014 | Kenwood Radio Communications
How hard is it to replace the finals in a kenwood ts-2000
Hi Damon,
It's Bloomin' hard, and it's tricky if you have little technical knowledge.
Yes Kenwood is a darn good brand, so to keep your Kenwood darn good, pay for the repairs, it's darn worth it.
Cheers,
Peter
Jul 02, 2012 | Kenwood TS-2000
Mike wire color coat.
1 is shield (and may also need blue for astatic mic or red for turner mic)
2 is audio (white on astatic and turner mics)
3 is Transmit (Red on astatic mic or blue on turner mic)
4 is receive (Black on both astatic and turner mics)
If your mic isn't an astatic or turner, email me with what mic that you have and I'll try to help. N1PTA@msn.com
Mar 18, 2010 | Radio Communications
Voltage of the backlight on the Kenwood TS-60 Need to replace the backlight on the Kenwood TS-60 Transceiver radio. Need bulb voltage, type or number. Any specifics would be helpful
check voltage of existing wire leads....any 12 volt wheat lamp will do or use resistor with 6 volt....copper electronics carries 12 volt grain of wheat replacements for .49
Jan 25, 2010 | Radio Communications
636l astatic mic
the wiring is the same as a cobra yellow n/c
Feb 02, 2009 | Astatic 636L Noise Canceling Microphone...
Astatic 636L Wiring
how do I wire a d 104 to a keen wood tm 221a radio
Jan 19, 2009 | Astatic 636L Noise Canceling Microphone...
Yellow wire on astatic 636L
that depends on what radio you want to use it with however looking at the astatic wiring handbook it doesn't seem to be used on most radios.
good luck
Rob
Nov 03, 2008 | Astatic 636L Noise Canceling Microphone...
Radio Communications Logo
91 people viewed this question
Top Astatic Radio Communications Experts
AnyMHz.com
AnyMHz.com
Clint Millett
Are you an Astatic Radio Communication Expert? Answer questions, earn points and help others
