Question about General Electric Kitchen Ranges
My general electric refrigerator stop working only has the internal lights on, what could be happening?
No even the outside dash is working
    Habit-Forming:
    New Friend:
  • 160 Answers
Probably internal circuit board damaged or defective. Call repair.
Posted on Nov 25, 2014
How do i fix a noisy freezer?
Usually its something to do with the compressor and it's probably starting to go, you will have to get a tech to come in and fix it.
Apr 02, 2015 | General Refrigerators
Freezer and refrigerator stopped working. Breaker NOT tripped. Removed all food from fridge and freezer. Still did not work. Breaker was shut off and turned back on even though it was not tripped. Works...
This usually indicate a weak breaker and is likely to happen again. Breakers may loose internal connection due to metal fatigue, and without visual tripping. i suggest that you replace the breaker before it happens again.
Jan 07, 2014 | Refrigerators
Dash shows bulb replacement necessary, however no bulb appears burned out. Can the dash light be removed?
Generally on high end cars, if the dash says there is something wrong,normally it is. I would not advise trying to remove the bulb from the car. This light will come on even if one small bulb on the outside of the car is out. Make sure you look at all the bulbs, there is generally one bulb out if that light is coming on.
Nov 30, 2010 | 2003 Lexus ES 300
My ice dispencer keeps icing up inbetween the botom of the ice holder and insde the chute delivery door.
The door of your refrigerator can not be closed completely so there is an air flow from outside to inside and also from inside to outside. This refrigerator uses more electric for this. The problem can only be solved by finding the hole and closing it.
This problem generally occurs because of the legs of the refrigerator.
Set the legs equally.
So you should find the problem and correct it.
Also this generally happens after cleaning.
I hope it helps.
Jun 06, 2010 | Kenmore Refrigerators
My refrigerator seems to run for long periods of time... do you know why?
This is most likely your defrost timer that has gone out. You should replace it soon to prevent an more problems from happening. This bad part could also cause your unit to freeze up and this could take more parts out.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number for the correct part to be sent to you.
We answer our customers calls from 7 AM until
9 PM CST so call us when you need us.
We look forward to hearing from you and wish you Hppy Holidays! Thanks, Ella
Nov 11, 2009 | GE GSS25JEMWW Side by Side
2002 Jeep Grand Cherokee Left Blinker Stopped working. No internal feedback (the green flashing errors for left don't turn on in the dash) Using hazards, only the right side flashed.
most common problem is a burned out bulb. i would check that first. If it still doens't work, and you have gone outside of the vehicle and can see that the turn light is flashing, then the light dash is probably burned out...kinda confused about your description, but i hope that this helps, good luck
Aug 17, 2009 | 1997 Oldsmobile 88
When I press Start - Runs for 5 seconds and stops.
I tried the "side dish" option with a glass of water in the microwave. The turntable continued to turn - it didn't turn off in 5 seconds- but then smoke started coming out of every vent. I think that killed it. I decided to go buy a new one.
Jan 14, 2009 | General Electric GE Profile CounterTop...
Dash light and tail lights not working
The dash and tail lights are controled by the first "click" of the headlight switch found on the turn signal arm.
If the fuses are good, then your turn signal arm has failed.
First click is running lights (dash and outside marker lights), second is headlights.
The 1st position of the 2 position switch has contacts internally that have worn and no longer complete the circuit.
Replace the turn signal arm.
Dan
Jul 20, 2008 | 1998 Land Rover Discovery
The temperature in the freezer ~30 Degrees F
Condenser fan motor replaced. Refrigerator did not work either, so I got mistaken describing the problem.
Jun 09, 2008 | Whirlpool Refrigerators
General electric refridgerator won't despense water in the door
Have the same thing happen a few times. The posted solution is correct, but in the mean time you can thaw the line by heating with a blow dryer inside and outside the door, and around the ice dispenser. This should take about 15 mins.
Jun 03, 2008 | Refrigerators
Kitchen Ranges Logo
59 people viewed this question
Top General Electric Kitchen Ranges Experts
reliableservice
ray gallant
EE Eddie
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
