1. How often do I change the distilled water? 2. Since I seem to use very little each night, may I just partially fill the reservoir?
See above
    Master:
  • 623 Answers
I'm assuming you're talking about a CPAP. If so, yes, just fill it to the fill line every night. Once a month empty it and clean it with vinegar, rinse it well and refill.
Posted on Nov 29, 2014
My iron is not releasing steam at all. The motor is going but nothing coming out. It has done this previously but only for a couple if minutes. Will not work at all and only just over a year old.
I suspect that the iron is clogged with mineral deposits. This happens when ordinary tap water is used - more so if your tap water is "hard". First and foremost, buy a gallon of DISTILLED water.
Cleaning it is very much like cleaning an auto drip coffee maker. Empty the iron into the sink. The first method is to pour white vinegar into the reservoir and set the iron to the hottest setting. Tip the iron flat to allow steam to escape. Press any buttons that allow blasts of steam, too. The vinegar will dissolve minerals on the inside of the iron and clogging the holes on the bottom of it. If all holes are cleared after the first time, flush DISTILLED water thru the iron. If not cleared, you can try this second method: Fill it with vinegar again and leave it sitting flat in the sink - unplugged - over night. In the morning, refill with vinegar as needed and try the first method once more. It should be clear at this point. Flush with DISTILLED water.
You can prevent this from happening again by using DISTILLED water only in the iron. There are NO minerals in DISTILLED water, which are left in the iron when water is boiled off inside it.
Jan 05, 2015 | Irons
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
I HAVE A vICKS VAPORSIOR AND HAVENT USED IT VERY OFTER THERES no STEAM COMMING OUT EVER I USE COLD WATER DON'T FILL ABOVE THE FILL LINE I ALSO CLEANED IT REALLY GOOD WITH CLOROX. aNY SUGGESTIONS???
The unit may simply has a calcium scale build up and it's blocking the water passage. To clean it, empty in water remaining in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water and fill the tank. Allow it to soak for at least one hour, then turn the unit ON. Place you hand in front of the misting nozzle to see if it's working. If you don't feel any mist, turn the unit OFF and allow it sit over night. If you do feel mist, allow it to run until the tank is 3/4's empty Turn the unit OFF, pour out the remaining solution and refill with Bottled Distilled Water. Run the humidifier until it's empty. This will flush the system entirely. In the future, I would recommend you use Bottled Distilled Water, instead of Tap Water. If you do, you won't have to descale the unit any more.
Hope this helped you, please let me know. Thanks.
May 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My coffee pot has an error saying PRIME, and will not work. Could you tell me what the problem is?
On the water reservoir there is a little black disk, a magnet, I think... If that is not against the machine it will display the prime error. Empty the water from the reservoir and tilt it so that the disk is against the machine. Place the reservoir empty back on the machine and fill it with water carefully as not to move the disk. When the water level gets to the correct position, the prime error will go away.
Mar 12, 2011 | Keurig B60 Coffee Maker
Radiator fluid
If use for summer, mixture ratio is 50% coolant to 50% distilled water, all year round use 80:20. Need about 3L. Ensure when filling reservoir it 's cap is taken off until coolant overflow from reservoir else keep filling until no more air bubbles comes out. Good?
Apr 16, 2010 | 2001 Honda ST 1100 Pan European (cbs-abs...
How to clean brown water coming out of iron
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
Apr 09, 2010 | Rival IR620 Iron
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Feb 24, 2010 | Bosch TDA8340 Iron
Water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Mar 14, 2009 | Rowenta Compact Steamer - White
I have a cuisinart Grind and Brew with a glass carafe - not pictured above. The self clean button keeps lighting up and I don't know how to run the clean cycle.
Fill the water reservoir with 2 cups distilled white vinegar and 2 cups water - then press the self-clean button. If the water doesn't start going through after a minute or two, just turn the machine on like you were brewing coffee. After the vinegar/water soultion has gone through the machine, brew one cycle of plain water to flush out the vinegar. If the self-clean light stays on, just unplug the machine for longer than 20 minutes, and the light should not come back on when you replug the machine. Good luck!
-Tha Mp3 Doctor
Feb 26, 2009 | Cuisinart Grind and Brew, 10 cup, black
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
