Question about Miele CVA 4066 Stainless Steel
The program screen lights up, but doesn't show any options. It's like it's locked up or something. How do we reset it to work?
My lock screen on galaxy 5 won't come on. It goes straight to home screen. Why is it doing that? It was fine 2 days ago. How can I get it back?
Three Reasons Why Screen Lock is Gone
1. Screen Lock has been deactivated (Instructions how to activate are at bottom.)
2. Android Screen Security File may have been deleted, and screen lock option is no longer on your devise.(A Factory Reset will restore original Android files)
3. Malfunction Somewhere in Samsung Phone. (A Factory Reset might work, but not guaranteed)
(How to Factory Reset phone at bottom.)
How to ativate Screen Lock and Security settings
1. Press the apps icon, it usually at the bottom of screen.
2. Find Settings and press that button to open settings menu.
4. Scroll down the menu to Lock Screen and Security, press that to open options menu.
5. The first option at top is Screen Lock Type.Press and Open.
6. You will have 3 lock types to choose from. Swipe Lock, Passcode Lock, Password Lock
(advise, do not forget password, only a hard phone reset, or an apk lockout file will get you back in)
If activating screen lock through settings did not work, or if option is not available, you can try to reset phone to the way it was when you bought it.
There is a couple things you should know.
1. contacts, photos, videos, downloaded apps, games, and everything not on the phone when it was first bought, or when you first got the phone will be erased.
2. You can back up contacts, photos, videos, in settings menu, scroll down to Backup and Reset. Or save to an sd card, and remove sd card before applying reset option
3. If you have an account (google or android email) associated with your phone, you will need email address, (example@any.com) and password to get back in phone after phone resets and turns on.) Dont remember password, Please create a new password now before continuing to reset to manufacture settings.
Reset Phone to Manufacture Settings
1. Remove SD Card, or its saved files will be erased.
2. Open apps, Open Settings Menu, Scroll Down to Backup and Reset.
3. Scroll down to bottom of page to Factory Data Reset.
4. Follow instructions to reset phone.
When your phone comes back on, Swipe Screen Unlock should be active at phone turn on, if screen lock is not showing try again to turn on in security settings.
If still does not work,
I am sorry, Your phone has permanantly malfunctioned. You can try your phone store, or a phone repair shop.
Mar 10, 2017 | Samsung Galaxy Cell Phones
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
Aug 28, 2013 | Kyocera wild card Cellular Phone
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
Aug 10, 2011 | Computers & Internet
LG WD-10160 TP. Display is showing code CL and no buttons work. I think it may be child lock but can't turn it off. The problem occurred when I turned off the machine & disconnected the water...
You are quite right, the Child Lock is engaged.
3 options for you depending on the machine:
Find the two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that should reset it.
Or
It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Or
If it has a program selector twist dial, set the selector to off or the end of a program (If it doesn't have, don't worry) Then, unplug from the mains. Leave for 20 minutes without tampering.
Power back on and the machine should have reset
Jul 01, 2011 | LG Washing Machines
Black Screen at Boot Up of Wii
Well if you have ever installed some type of a fail safe program you can enter it by either pressing the reset button and holding it immediately after powering on the Wii from when the light is RED. Or you can plug in a game cube controller and hold the Y button when you power it on from the red light. Supposing this works, and you log into something like starfall, then you can try something like change the IOS that the system menu runs off from to IOS249. This option would be found somewhere in the settings options I believe. I had a similar problem and this worked for me.
Oct 10, 2009 | Nintendo Wii Console
99 Grand Am GT - power locks don't lock
easy one... many cars have the option of programing the lock sequence. Your manual (if you own one) shows you how to reset or program door locks. Someone may have press and held the lock switch in one direction for a short while which will put it program mode. If you dont have the manual you can try to hold the lock button torward lock for about 5-10 sec. You should hear a tone, then try pressing the switch again to reset.
Aug 21, 2009 | 1994 Pontiac Grand Am
My scanner is stuck on ''all chanels locked out'' I don't know how this happened. I have tried resetting and iitializing but nothing is working.
If you reset and/or re-initialized the scanner, then you quite possibly have deleted the frequencies you had programmed in it. Can you see any frequencies showing when you have the scanner in manual mode? If so, try pressing the lockout button, which usually is marked with something like L/O. If L/O appears on the screen, then that channel is locked out. Press the L/O key again to unlock it.
Jun 05, 2009 | Radio Shack Pro-2096 Base Scanner
I need to somehow reset my factory alarm on my 1995 Nissan Maxima
this is how most nissans program the key fobs.
get in the car and manually lock the drivers door with the door switch.
put the key in and out of the ignition about 10 or 12 times until the hazard lights flash once.
turn the key to the ignition setting so all the dash lights are on,but do not start the car.
click the lock button on the remote fob.the hazards should flash once to confirm.
turn off ignition and remove the key.
unlock the drivers door and open the door.
the remote should now work.
if that does not work,the dealer can reprogram the fob with the obd diagnostic system.
May 26, 2009 | 1995 Nissan Maxima
Htc locked touch screen mal functioning
Try mDesktop for remote control from your PC to unlock the phone.
Apr 10, 2009 | HTC Touch P3450 Smartphone
Miele CVA 4066 Stainless Steel Logo
55 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
