Question about Home
Would like to get hold of an instruction manual for a 1970 sekio 30 day wall clock
The internet
3 Suggested Answers
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Posted on Jun 22, 2009
SOURCE: skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Posted on Feb 01, 2010
How do I set T101 intermatic T101 timer to 7:30 PM
PROGRAMMING INSTRUCTIONS 1. TO SET "ON" AND "OFF" TIMES: Hold trippers against edge of CLOCKDIAL, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A. 2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
http://www.intermatic.com/-/media/inriver/10162-9164.ashx/T101-Instructions-EN
Mar 23, 2017 | Intermatic Hardware & Accessories
Manual/instructions for Timex model#75324 atomic clock
Here is a link to the user manual: http://www.acurite.com/media/manuals/75324T-instructions.pdf
Mar 09, 2015 | Timex Atomic Digital Wall Clock
I would like to have the instructions for operation of the Timer.
You posted under Woods 59403 timer
If you have different Woods timer, look at images at link below to identify timer.
Add a comment at any time
http://waterheatertimer.org/Woods-timers-and-manuals.html
59403 timer manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Plug lights into timer.
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
Dec 02, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I cant figure out how to set it.
http://waterheatertimer.org/pdf/Woods-59203.pdf
The manual has step by step instructions.
Plug timer into wall to recharge battery.
If battery will not charge, the timer is no good.
Press reset to clear memory.
Select am/pm format by holding clock button.
Set current time by holding clock button down while pressing hour, and then minute and then day
To program timer:
Press program button once and program1 ON displays
Press minute button to set program1ON minutes
Press hour to set program1ON hour
Press days to choose the day or group of days for program1 ON
Press program button again and program1 OFF displays
Press minute to set program1OFF minutes
Press hour to set program1 OFF hour
Press days to choose same days for OFF that you chose for ON
Press program button and program2 ON displays
etc.
To exit programming, press clock
A conflict in programming will cause timer not to work as expected
Make a schedule before programming to avoid program conflicts
maximum load 1000 watts
Nov 08, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Skyscan atomic wall clock 87315. Changed battery
Jan 31, 2010 | SkyScan Audio Players & Recorders
Cannot reset my SkyScan Atomic clock after changing batteries
Online manual is at link http://skyscan.info/content/manuals/25-model-87315.html
Dec 29, 2008 | SkyScan 86709 Atomic Wall Clock
3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Oct 25, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Arx 1970 car cassette
Setting the clock:
1.Press and hold the Band Button (on the left of radio)and the Clock setting button (button No:4 on the right) to display the clock.
2.Press and hold the Band button and the Clock Setting button again for 2 seconds or longer for the clock display adjustment.
3.Press the SEEK UP Button (on the right of the radio with the arrows) to set minute.
4.Press the SEEK DOWN button to set hour.
5.Press the Band button to confirm the clock setting.
Jul 11, 2008 | Clarion ARX6670Z Cassette Player
Home Logo
42 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
