Question about Keurig Platinum Plus B79 Platinum Coffee Maker 1 Cup
Keurig b79 platinum plus leaks water all over the counter. I believe it's from the reservoir. How do I fix it?
Nothing
  • 636 Answers
Time to replace. Theres no room for profit if you replace the reservoir.
A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
Posted on Nov 22, 2014
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
Mar 12, 2013 | Keurig Platinum B70 Coffee Maker
Keurig b70 water tank leaks out all over the counter
Shut-off valve failed, retry a second time and it will reset accordingly.
Dec 31, 2012 | Keurig Platinum B70 Coffee Maker
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
Won't brew. Screen says 'brewing' but nothing happens. 'descale' showing on left side of screen.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 06, 2011 | Keurig Platinum B70 Coffee Maker
Coffee maker says it is brewing, but nothing is happening.
When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths. Good Luck.
Jul 13, 2011 | Keurig Platinum B70 Coffee Maker
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum is clogged
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum Plus B79 Platinum Coffee Maker 1 Cup Logo
65 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
