Question about In Microwave Ovens
<!-- from fixya rte -->How do I replace bulb in oven - In Microwave Ovens
  • 637 Answers
Quite honestly I do not recommend that any untrained person open up a microwave. I've read about too many people get across the capacitor and be KILLED. It's not worth it. Buy a new one.
A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
Posted on Nov 22, 2014
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
How do I change the light bulb?
It is hard task.
  • You will need special tools, e.g. Torx screwdriver (star) and other
  • Be careful. Oven must be disconnected from mains.
  • The disassembling is complicated and procedure consist of more steps.
  • Microwave oven lamps bulbs are very special. They often do not have usual lamp cap. See Microwave Oven Lamp Bulb with Base
  • Watch this video as example what will your task:
Microwave Oven Lamp Replacement Samsung T170 Light Bulb UK
Some oven lamp types:
Home Office Light Bulbs Microwave Bulbs
Jan 28, 2016 | Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Why do the light bulbs stay lit after I have replaced the bulbs?
If the bulbs were replaced with power on the oven, the the device supplying the power to the bulbs (possibly a triac) may have been shorted out.
Jul 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Replace oven light bulb in FMV 156D
Hello Jim Rogosheske - To replace light bulbs, first I suggest disconnecting power to the microwave oven at the circuit breaker panel or by unplugging. To release cover, remove the screw on the light cover. Replace light bulbs with equivalent watt bulb available from your manufacturer or a parts distributor that they recommend. Bulbs are also available at most hardware stores or lighting centers. However, it is not recommended to use a bulb larger than 30 watts. Close light cover and secure with screw that was previously removed to release cover. Be aware that light cover may become very hot. Do not touch glass when light is on.
Oct 11, 2012 | Frigidaire FMV156DC Microwave Oven
Replacing light bulbs?
Replace the burned-out bulb with a 120 volt, 30-watt incandescent bulb (WB36X10198), available from your GE supplier
  • 1 To replace the oven light,
first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
  • 2 Remove the top grille by
taking out the 2 screws that hold it in place.
  • 3 Remove the charcoal
filter (if present) to access the light cover (see Remove Charcoal Filter section).
  • 4 Remove the light cover
located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size and type bulb.
  • 5 Replace the light cover
and charcoal filter (if present).
  • 6 Replace the grille and
screws. Connect electrical power to the oven.
The full owners manual can be found here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40474.pdf
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
4 Replace the screw.
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
plug.
3 Next, remove the screw
located above the door
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
