I have tried useing tips on youtube to no avail . or is there a way to reset it completely as grandson is now old enough to play older games.
Youmay have to reset the complete unit since you cannot remember the code. Hope this helps.
A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
how would i do that.?
Steps 1 Power on your Xbox console and television. 2 Navigate to and select “System Settings” from the Xbox Home screen.On some versions of the Xbox 360, you may need to select “Settings,” followed by “System.” 3 Select “Console Settings.” 4 Navigate to and select “System Info.” 5 Write down the serial number of your Xbox console.[1]Alternately, you can obtain the serial number from the back of the console itself or from the inside of the oval door located on the front of your console.[2] 6 Press the “B” button on your Xbox controller two times to return to the System Settings menu. 7 Navigate to and select “Storage” or “Memory.” 8 Navigate to “Hard Drive” and press the “Y” button on your Xbox controller. The Device Options menu will display on-screen. 9 Navigate to and select “Format.” 10 Select “Yes” when prompted to confirm that you want to delete all content from your Xbox. 11 Enter the serial number for your Xbox 360 when prompted to by your console. 12 Select “Done.” Your Xbox 360 will now begin to reset, and restore itself back to its original factory settings.
SOURCE: Xbox 360 won't play old xbox games?
If your console is hooked up to Xboxlive and has a Hard Drive connected to it you will automatically be prompted to update upon insertion of the original Xbox title. Your console will restart when it's ready and you should be able to play.
*If you do not have a Hard drive you cannot play original Xbox titles.* The original Xbox Memory unit will not work in Xbox360 and the original Xbox games have no access to the Xbox360 memory units.
If you have a Hard Drive but your Xbox360 is not hooked up to the internet you can either order a disc for free from Microsoft by going Here
or burn the needed information onto a disc by going Here
SOURCE: XBOX 360 won't play burnt games
You need to have your console modded in order to play burnt games.
Visit: www.xboxmod.info
They can mod it for you and you will be able to play burnt games!
SOURCE: Cannot remember my Xbox 360's passcode and reset answer!
Try these steps first:
Go into settings
.... console settings...then device settings or the
blue screen then go...
left trigger
right trigger
x
y
left bumper
right bumper
left with left stick
up with left stick
right with left stick
x
If that doesn't work then call 1-800-4MYXBOX they will walk you through it.
SOURCE: Xbox 360 reset Code
Since that didn't work. Try to go and run "Initial Setup" again on the 360. That should solve the issue. If somehow it doesn't just give Microsoft a call at 1-800-4MY-XBOX and they CAN take care of that for you.
