Question about Invacare Health & Beauty
I have a zoom 400 scooter, it goes a few feet than stops. Turn off power a few minutes it goes again a few feet. whats problem or how can I check?
I have replaced the batteries with new ones. still the same problem runs and then stops after a few feet.
    Top Expert:
  • 26,670 Answers
Bad connection or maybe brushes?
Posted on Nov 22, 2014
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
gewiz
  • 1271 Answers
SOURCE: AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
Posted on Jan 26, 2010
  • 347 Answers
SOURCE: Battery isn't charging, no handbook
be sure of model etc & order a manul from the dealer,then once read the basic guides,if no joy then book will advise you to get in touch with a qualified dealer.
Posted on May 12, 2010
  • 177 Answers
SOURCE: Invacare Zoom 220 mobility scooter will not run
Hi. When the machine is on, does it display a flashing light or LED on the display for a fault code? Is the free-wheel lever switch operating correctly?
You might have a sticky brush in the motor. Take the brushes out and check their condition. If the brush caps are not tight enough then the current arc's on to the side of the brush, and it jams in the brush holder.
Check the resistance through the motor before touching the brushes. Check motor and battery connectors for continuity and any sign of heat or melted plastic. Check operation and resistance of the brake unit. Most controllers in mobility scooters are quite reliable, so always eliminate all other possibilities before looking at the controller. Good luck. Neil.
Posted on May 29, 2010
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Posted on Jun 07, 2010
What is problem with my rascal 305 four wheel scooter
your problem is related to the overload breaker on the chair you need to figure out why the breaker is tripping either due to batteries going bad or the brushes in the motor need adjusting or replaced , also you need to check the automatic brake is releasing completly a dragging brake will cause the auto reset breaker to trip
Oct 01, 2014 | Health & Beauty
How can I fix This problem. after about 1.5 miles the scooter comes steadily to a stop. waiting for a few minutes it will go again Ok.
The motor is overheating. The service manual will tell you how to test. Pride has a service manual you can download from their website.
May 20, 2014 | Pride Go-Go Ultra X 4-Wheel
Scooter problems
Possibly loose or broken wire somewhere. Take it to a dealer
May 08, 2014 | Health & Beauty
My srtrider will only go for a few feet then comes to an abrupt stop its abit like the back wheels jam..but then it will go for another couple of feet then come to a stop again there are no warning lights...
If your batteries are running very low, this is the most likely source of your problems. 80% of my scooter repairs involve batteries. The fact that your scooter runs is a good thing. The fact that it runs only a few feet and gives you no error code when it stops indicates the electronics have no battery power to indicate a flash code. The back wheels jamming probably relates to a no power condition causing the brake to lock (it takes power to release the brake and turn the motor)
This scooter uses two U-1 batteries that last between 1 and 2 years. From your description, I would replace the batteries first and make any further determination of any problems, if any,after that. These batteries are available locally at a large discount (between $50 and $160 each) and can be installed with basic tools, saving you money on the labor charge.
Shop around for the best price. Charge the new batteries fully before use. Enjoy.
Hope this helps.
Nov 25, 2010 | Electric Strider Midi 4 Wheel Mobility...
The motor or transaxil lock up and stop the
Hi. Sounds like the circuit breaker ( over load switch ) is tripping out. If you let it sit for a few minutes, does it start to work again? Does it stop when you are driving onthe flat ground, or when you drive up a slope.
I have had cases where this happens to scooters going up a slope, usually because the circuit breaker is rated to low. Sometimes a faulty or burn't out motor will cause this fault.
Also check that the brake solenoid ( free-wheel )is releasing properly. Can you push the scooter when the brake is released?
Good luck. Neil.
May 31, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
When I stop the scooter after travelling a short
Hi. Yes, most, but not all machines have a "sleep" mode. More for safety than any other reason. Neil .
Oct 31, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Health & Beauty Logo
142 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
