Question about Air Tools & Compressors
I have oil leaking into the hose on my Kraft tool 500 texture sprayer any idea whats going on? when I turn it on it spits out the end of the hose
    New Friend:
  • 44 Answers
You have oil bypass on the piston or the oil level is to high
Posted on Nov 26, 2014
I have a Kraft tool texture sprayer 500 model, I have noticed lately that the oil is slowly syponing out of the holding tank and its running into the air hose so when I turn it on it spits out oil lef
As the hopper gun does not use oil, you are either spraying an oil based material which is separating in the hopper, or you are using a compressor that is leaving oil in the airline; this could happen if the compressor is worn and oil is leaking past the piston into the air.
Nov 22, 2014 | Kraft PC501 Standard Texture Gun & Hopper
06 ram 1500 TRX, noticed a leak and coolant spitting while running. Cant find source. Leak appears to from behind the altenator. Anyone have an idea what it could be?
Carl,
You're gonna have to get down and look. The first things that come to mind are the easy ones...Look at mounting surfaces (head, water pump, freeze plugs) or hose ends. You might be able to borrow or rent the tool that attaches to the filler on the radiator, and pump pressure in there. You'll be able to find the leak then. Good luck.
Jan 07, 2012 | Dodge Cars & Trucks
I have a 1990 chevy beretta with a 3.1 and im having trouble with it losing coolant and overheating it dosent seem to be any gaskets but i cant tell where the leak is coming from i do know that the coolant...
there are some coolant heater hoses right above the exhaust manifolds check those, also check engine oil for discoloration due to coolant contamination. may have moisture on dipstick, oil may look like a chocolate shake texture. if so then most likely internal intake gasket leakage.the best way to check for hose leakage is to pressure test the coolant system if possible.
Sep 06, 2011 | Chevrolet Beretta Cars & Trucks
How do you stomp texture or stipple a ceiling?
There are a ton of different ways you can get this done. You can purchase what is called a popcorn sprayer that works like an air powered paint gun for ceilings of course you'll need a compressor also. Some hardware stores rent this equipment. You'll be spraying on a material also available at most local hardware stores that is sort of like drywall joint compound only a different consistency.
If you choose to texture by hand you can use a number of tools to get different textures paintbrushes, brooms sponges, precut stencils, rags, etc.. Basically clear out the room cover anything you don't want to get messed up gt a bucket of drywall joint compund your texture tool of choice and a trowel. spread a thin layer of compund on the ceiling and texture away. The thicker you spread it the more texture you will get. Be sure to have a helper that can switch off as this does get tiring, and you'll need extra hands to help get clean water for your tools so your texturing project is consistent. Plan accordingly, this is not a project you want to leave halfway through and finish another day. If you start a room, finish it. or you will notice the difference in texture every time you sit down and try to relax.
Feb 15, 2010 | SK 17855 Long Reach Needle Nose Compound...
Ram moves jerkily and then doesn't recoil
Check hydraulic fluid and ensure it is at the proper level - Still have the problem
Check hydraulic filter...may be clogged.
Check hoses and ensure there're no leaks.
Good Luck,
Mike...
Nov 22, 2009 | Kraft POW R KRAFT 65575 7 ton 2 Speed...
Can't pull the trigger
Probably the paint and texture have clogged the orifice as well as the feed tube up. Hope the paint was water based. If so, set the gun down in a bucket of very hot water with the trigger tied open.
It may take several soaks. Each time you check it put the air on and pull the trigger a few times. Eventually it will unclog. By the way, you should take the orifice completely off so there is no restriction.
If it was solvent based you are pretty much out of luck.
May 25, 2009 | Wagner Power Tex Texture Sprayer #0520000
Mold and smell from Maytag washer
The mold will be growing in the upper parts of the agitator basket above the water line. Spray these areas with a bleach/water mixture using a spray bottle. Turn off the hot water valve to your washer. Disconnect the hose connected to this valve. Connect a leak free garden hose to the valve. Connect a garden sprayer to the other end of the garden hose. Turn the hot water valve back on. Check for leaks. Use the garden sprayer to rinse and remove the mold. Be careful to keep all of the water in the agitator basket. Turn off the hot water valve. Reconnect the hose from the washer to this valve. Turn the hot water valve back on. Check for leaks. Run a wash cycle with an empty load.
Jan 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have borrowed a kirby from my friend and i would like to wash my couches, please would you be so kind as to assist and let me know what tools i would need to use to be able to do so??
You need the upholstery attachment (it looks like a trigger sprayer with a plastic jar attached)You MUST have the foam screen that fits on the front of the trigger,without it,you will only get solution.The trigger sprayer fits on the end of the hose.The other end of the hose fits on the blower end of the machine.You must remove the bag,and attach the hose at this end.The trigger sprayer deposits the foam,and you work the foam in with a soft cloth or brush.When dry,switch the hose to the suction side,and vacuum out the foam.There is also an adapter (about the size of a styrofoam cup) that attaches to the front of the machine to allow it to be used when using the hose on the blower (bag) side.
Dec 14, 2008 | Vacuums
Cav4000aww magic chief washer
water is bypassing through the water inlet valve
easy fix go to lowes ect and get a cap plug for a water hose male end and screw it onto the water valve that has no hose connected to it
you could also screw on a water hose sprayer onto the valve if you have one on the end of the garden hose just make sure that it is turmed off
May 17, 2008 | Magic Chef Washing Machines
Air Tools & Compressors Logo
48 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
