Why does the screen have an approxmate 2 inch gap on the top and bottom of the channel broadcast?
  • 637 Answers
Thiscomes from your format settings on your TV. Press the format button it is between 487 2010 at. A thumbs up would be greatly appreciated if this answer is helpful to you. Have a GREAT DAY and GOD BLESS YOU.
Posted on Nov 22, 2014
Testimonial: "I do not have a format option, nor is there one on the remote. The remote is very simple and only has a main menu which gives other options but "format" is not a choice. I have looked through all other options and there is nothing regarding screen size."
3 Suggested Answers
  • 267 Answers
SOURCE: Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
Posted on Jun 26, 2009
  • 127 Answers
SOURCE: sharp aqous picture error
You Vertical Problem can you go to advance settings to adjust
vertical Size? Or center the picture
Posted on Nov 02, 2012
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
I cant keep the picture at full screen fom channel to channel
The reason for this is that the incoming signal is not always the same. Stations broadcast in different formats from 480i to 1080. If the bars top and bottom or side to side bother you then you'll have to stretch the picture (try different modes) to keep the picture screen full.
Dec 24, 2009 | Dynex DX-LCD37 TV
LG 37 inch tv loses top and bottom of picture on some channels
that is because some channels are being broadcast in letterbox mode you should be able to go into your menu and adjust to full screen.
Dec 09, 2009 | Televison & Video
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Jvc projection tv
try this site http://www.sharefx.net/index.php
Jul 16, 2008 | JVC AV-56WP74 56" Rear Projection...
Yellow line on right side of screen
Go to this website and read what it has to say, your TV's have major problems.
http://esupport.sony.com/sxrdsettlement
Apr 20, 2008 | Sony KDS-R50XBR1 50" HDTV
SHADOWING
jesus have you move that tv thats new to me but surely techman know about.....good luck
Aug 08, 2006 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
