Only thing I've tried is pressing and releasing the auto/manual switch on the turntable.
SOURCE: Crosley CR79 4 in 1 Entertainment Center
Wild guess but try this with the power off. Rotate the platter clockwise about 5-10 turns. You may feel internal mechanical engagement as you do it. The cueing mechanism may cycle it through its motion and return it to the rest.
SOURCE: plugged in, switched the switch to phono, set the
hi,
check the belt may be broken or loose. if found so replace it.
ok
SOURCE: Aiwa turntable px-e860: Hi, I've inherited
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. [email protected]
SOURCE: Problem with Auto Return on Thorens Turntable TD 147
Leo J. Nesuahecner The bottom of the tone arm shaft has a white plastic cup with a single screw in it. You need to remove a large square plastic cover also with a single screw to access the cup. This cup has a magnet in it. As the arm rotates to the end of the record this magnet trips a switch that pops the solenoid under the start stop lever. By loosening the screw on the white cup you can rotate the cup so the magnet hits it's switch sooner or later . It is touchy so prepare to to spend time fiddling with it. There is a small pointer on the cup you can use to grab with your fingernail to rotate the cup counter or clockwise. Hardest part is standing the table on end and operating all functions with the left hand and rotating the cup to various positions. Remember to gently tighten the screw after each adjustment or it will move when the tone arm is moved.
