Hi My washer is 10d52 is just washing Not drying and show E17 I dons know what's problem
  • Washing Mach... Master
  • 744 Answers
Hello Khan;
My name is Peter. I am a retired field service appliance technician.
The highest probability is, you have a bad heating element. Lets check it out:
Turn the power off to the dishwasher at the breaker box. Turn the dishwasher on to test that there is no power.
Regardless of the dishwasher model they are easy to disconnect and remove. In the bottom of your dishwasher you will see a metal form shaped bar. This is your heater.
Remove the bar and inspect for cracks. If you have a multi-meter set your meter to Ohms X1. Touch one meter lead to one end of the heater contact and the other meter lead to the other heater end contact. If the meter either reads '0' or infinity the heater is bad.
Also, make sure the contacts on the heater and where it connects inside the dishwasher are good and clean.
Posted on Nov 22, 2014
3 Suggested Answers
SOURCE: I just bought my washer
When the washer shows error code E17 you need to turn the tap fully on and check that the supply hose is not bent or jammed up, next make sure the filter is clean. Then make sure the water pressure is not too low. After you do all that, run a load with no clothes in the washer and use one cup of white vinegar and the code will dissappear
Posted on Nov 19, 2009
SOURCE: e17 error code
Got an E17 Error today on a Bosch 6450 Series washer (the user manual says Bosch Vision 300/500/DLX series). Here's what I did to fix the problem.
- Tilted the unit back, propped up the front with some 2x4 (lying flat; that's all the room I had).
- removed 3 screws (Torx 20 I think) under the front lip. Then slid the cover (below the washer opening) down. This revealed the pump to empty the washer, a manual door lock opening pull rod, and a drain line (?)
- Looking through some holes in the front panel I saw some water on the bottom of the washer... but I spent a lot of time with the pump cleaning it out first (some zipper pull got in there and made a lot of plastic shavings). - Ultimately I got my hand the bottom of the washer and soaked up the water that I could find. That's when I realized
- there is a micro switch mechanism at the bottom near the front. This must be the "AquaStop". The mechanism contains a bit of styrofoam that floats up on any little amount of water that collects under it and triggers the microswitch. So, I removed that unit, wiped the water up... put it all back together. No more E:17 error.
Still don't know how the water got there in the first place though.
Posted on Jan 01, 2012
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
How to fix error E17 code on eziset 9.5 kg top loader
Supply problem.
Check to see if water hose is plugged and test water pressure.Check water valve supply shut off.
See if filter is plugged.
Run full cycle w/no clothes in washer. Add 1 cup of vinegar,no soap.
May 03, 2014 | Washing Machines
The "key" shows on the screen
Hola! You have activated the Child safety lock! Yes Mam! Usually to unlock it you hold down two buttons X 5 secs. You OWNERS MANUAL will tell you about this feature! Good wruck!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 16, 2014 | Siemens Washing Machines
Un lock child lock 10d52 seimins washer dryer
to deactivate the child lock, set program to Easy-Care and hold option down arrow for 5 seconds. If still it does not get unlocked then Try pressing "dry" & "spin" together for 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds. If this doesn't work then try pressing "options & select" till the light goes off. Also try and press ECO and rapid buttons together for more than 10 seconds.
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD
Jun 26, 2011 | Washing Machines
I just bought my washer today and it won't finish the first cycle. It is showing "E17" and won't drain. What does "E17" mean and how can i fix my washer. Help!!
Nov 19, 2009 | Bosch Washing Machines
E17 error code
Mar 29, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Washing Machines Logo
Top Washing Machines Experts
