Question about Lexmark E360DN LASER PRINTER N Laser Printers Feeder Tray
How do we correct a 900.57 firmware error. What does this mean and how do we get printer to print?
    Problem Solver:
  • 5 Answers
Windows 7 is the operating system on your computer. Firmware is the operating system on your printer. You need to update the firmware on the printer.
Firmware update instructions:
  1. Download the appropriate update file below
  2. Unzip the downloaded file
  3. Read the README file (located in .zip file) before updating
support lexmark com
Posted on Nov 28, 2014
What does the error message - 49.4C02 - mean?
49 errors are often caused by the printer receiving commands it does not understand. Sometimes hardware failures but not often. To determine hardware or software, turn the printer off. Unplug any network or USB cables attached and turn printer on. If it will come to ready with no cables attached, then likely you have a print job that is causing problems. This can be fixed by installing the latest firmware from HP.com. Download the Easy Firmware Update Utility version. To install this update you need to have the printer connected to the computer, so check the print queues to make sure that there are no print jobs pending, delete them if there are. Plug the network or USB cable back in. Wait a couple of minutes to make sure that the 49 error does not come back. If printer stays on ready, run the upgrade utility and your problems should be gone. If it is a hardware issue then a different set of trouble shooting steps applies. Post back if this does not fix your problem.
Aug 15, 2014 | HP CP3525DN Color LaserJet Printer
We have an error 49.283 come up on our HPLJ 9050n, how do i fix tis
A 49 error is usually caused by either a corrupt print file or file that the printer does not understand. In most cases updating the firmware will resolve these problems. First, unplug all usb and network cables attached to the printer and power it on. If it comes to ready that is a good sign. Make sure that there are no stale print jobs in the queue of any computer that prints to the printer. Plug the network or usb cable back in and see if the printer continues to stay on without a 49 error. If yes, then go to www.hp.com and download the current firmware for your printer. Most firmware updates for these units are available as an easyupdate utility. Run that utility from any computer that normally prints to the printer. Select that printer from the drop down menu in the utility. After the firmware has been updated the printer will restart and you are ready to go, with your 49 error a past memory.
Jul 09, 2014 | HP LaserJet P4015N Printer
49.38.07 error
It a common HP error. It is a non spesific error. Usuly the printer having problems with a specific job you trying to print . The firmware needs updating, delete that job and turn off and on the printer, make sure IP address ,subnet mask and gateway are correct. Also win servers and DNS settings are all correct.update printer driver. Try printing via host name not IP.
Apr 19, 2014 | HP Laserjet Enterprise M4555 Mfp Laserjet...
49 error
49 error means firmware error..
solution:
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error.
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again.
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
I have an HP5550dtn showing the error code 49.4c18. What is this and how do I get the printer back on line quickly?
Most 49 errors are caused by a newer program you are printing with that the printer does not fully support. You need to upgrade the firmware on your printer to the latest revision as this will fix 99 percent of these errors.
First you will need to clear any jobs that are in the print queue, then restart the printer. If it comes to ready, you will be able to upgrade the firmware. If not, disconnect any network or usb cables and restart again, if it comes to ready, it means there is still a stale print job and you should check the print queues again and restart your computer.
To update the firmware, download from here and follow the instructions in the readme file that is part of the download.
Apr 10, 2011 | HP LaserJet 5550dtn Printer
I am getting Error 49..turn off and turn on error again and again from HP 2605 Color laser jet printer. Plz help.
It's a firmware error.
Do ALL your print jobs give this error. If it is just one job that causes the error, something is corrupted with the software.
If every print job causes the error, it's the printer. Try printing after removing DIMMs from the printer. If you can try plugging the printer into another port on the computer or router.
When all else fails, go to www.hp.com/#support and download the latest firmware and install it.
By all means READ the directions first.
Jan 31, 2011 | HP LaserJet 2605dn Printer
How do i download firmware for a 900 firmware error - lexmark 540n
Before you download firmware, the 900 error usually indicates a software or communications problem. Please try to do the following.
Disconnect every cable, except for the power cord and turn off the printer for 30 seconds or more to clear its memory
  • Clear all jobs in print queue then turn on the printer and see if the error returns
  • If the error does not return, try to print a test page from the Test Menu
  • If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  • If the
Jan 17, 2011 | Lexmark Optra T620 Laser Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
What does error #49.4c02 Mean? How do I clear the
49.XXXX PRINTER ERROR
To continue turn off then on
No error message will be in event log.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications. On rare
occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application. If the job prints, go back to
the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer. See Calibrate now.
Mar 19, 2009 | HP LaserJet 4600dn Color Printer
Lexmark E360DN LASER PRINTER  N Laser Printers Feeder Tray Logo
160 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
